Anybody in fargo wanna help change a clutch?
Discussion in 'General Subaru Discussion' started by HiImBrian, Aug 16, 2009.
  1. HiImBrian
    HiImBrian Member
    I've got a 98 2.5rs and the clutch has had a little slip in it for a while now. I figured since I've got a week off, I should try and get it done before classes start. I'll gladly supply food/drank/money for lending a hand. I've replaced a clutch before, but never on a subaru. I'd rather have an experienced person around to work with.
    I have tools and a garage, but it's up to you where you'd like to do it. Thanks
  2. HiImBrian
    HiImBrian Member
    bueller...bueller...
  3. Aegis
    It's Sunday dude, you might not get a bite until later tonight. :(
  4. HiImBrian
    HiImBrian Member
    lol I know it's sunday. Haha what do ppl do on sundays except sit around all day. Or is that just me?
  5. john
    john Well-Known Member
    It's just you. :)
  6. KA-T_240
    KA-T_240 Well-Known Member
    Talk to colin.
  7. Colin
    Colin Well-Known Member
    yeah, i got a tranny swap tomorrow and im busy tues, wed might work.
  8. HiImBrian
    HiImBrian Member
    I'm assuming you'd rather do it at your place? Any time preference?
  9. Colin
    the place doesn't really matter, but 6 ish should work.
  10. HiImBrian
    HiImBrian Member
    Forgive me for having to ask, but are you talkin AM or PM? lol
  11. Colin
    pm. funny though. I suppose if it's slow at work i could do it at 6am. lol
  12. ShortytheFirefighter
    Colin, I have to ask, do you hold the car up with one hand and then just pull the tranny out with the other?
  13. KA-T_240
    ahahhahahahahahha! I wonder the same thing.
  14. greg donovan
    nah, he just crawls under and disconnects everything and then just grabs ahold of the intake manifold and lifts it all right out the top.
  15. bubba_crx
    bubba_crx Well-Known Member
    lmao... wouldnt suprise me...
  16. Colin
    no, I pull it into the mechanics bay, unhook the neg battery terminal disconnect the intercooler from the turbo and place it out of the way, then take the master cylinder off the tranny, unplug all the tranny wiring (and the EGT and front O2 because I'm doing the upipe to) then the pitch stop is disconnected and I remove the starter and the clutch fork gets loosend
    I then raise the car and remove the front wheels, and camber bolts. then take the car all the way up. I then drop the dif gaurd and remove the driveshaft I then remove the remaining tranny bolts and then set up the tranny jack. I use a punch on the pins in the axles and push them off.
    I pull the tranny mount and lower/work the the tranny bakc and off.
    Then I lower it out of the car. next i disconnect the DP and the heatshields/sensors heat shield take one engine mount nut off and jack the engine to remove the upipe. re-install the new pipe. and reverse the process.
    Only I forget/undertighten a starter bolt. Then after I return the car, the starter works it's way out a 1/4 inch and I need to fix it in the parking lot of the local go kart park.
  17. Colin
    I have only done this once. and it was to a light SOHC 2.2.
  18. greg donovan
    a friend of mine prefers to pull the engine for clutch jobs since he doesnt have a car lift. he is pretty fast at it that way now.
  19. Back Road Runner
    Repetition creates speed. It's nutty what some of you guys can do in a small time frame. I'm slow as hell at new stuff typically, but anything I've done a bit is quick. The last time I took apart an engine was in shop class...15 years ago. :laugh: I want to do timing belt, cams, and clutch/flywheel sometime within the next year, should be a fun process whenever that happens.
  20. Bookem
    Bookem Well-Known Member
    I finally logged on and pm'd you with all the details if you are still interested.
