Anyone a fender rolling expert?
Discussion in 'Modifications And Maintenance' started by COBBsoobyStage1, May 9, 2007.
  1. COBBsoobyStage1
    COBBsoobyStage1 New Member
    DT Minni
    I'm interested in getting my fenders rolled. There's beer and pizza in it for you. Or whatever you charge. Anyone? Anyone?
  2. Colin
    Colin Well-Known Member
    Moorhead
    I roll fenders, even own a fender roller, I actually just rolled a miata out to fit some beautiful deep dish tonight. But i'm in moorhead.
  3. carl
    we gotta gooooo
  4. COBBsoobyStage1
    DT Minni
    it'd be worth the trip. my alternative is going it myself...
  5. Justin
    Justin Well-Known Member
    St. Paul, MN
    how about more than just rolling...actually flaring fenders out more? methodless?
  6. carl
    we gotta gooooo
    pulling starts to get risky - on some fenders that can lead to rippling, my STi seemed to have fairly hard fenders that I don't think would have pulled very well
  7. Colin
    Moorhead
    Fender "flaring" is easy or riduculously hard. If you don't care about paint, or are going to get repainted, you can flare like mad, then sand. Also flaring tends to require a lot of heat to get a smooth finish with out sanding. If you are worried about paint, then it takes time. Lots of time.
    Also when you're flaring you're running the risk of buckling. Especially in the rear quarters. You need enough heat that you can actually stretch the metal otherwise you get "waves" in you panel or buckling can start.
    So short answer: yes I can flare, but I'm no bodyshop guy, so I couldn't garauntee your paint or your panels. If you can weld, widebody would be easier.
  8. Justin
    St. Paul, MN
    i ask because i'm supposed to have a fendor roller thing on the way, i've already paid to rent it. feel like coming to play on the L with it? the car has rust so i'm not to worried about stuff....i guess i wasnt to worried about anything on the wrx either lol
  9. COBBsoobyStage1
    DT Minni
    I think all I need is the rear fenders. I'm going to be sitting almost even w/ the tire when I install the cobb springs.
  10. Colin
    Moorhead
    I don't think I could make it down this weekend, sorry, buts it's my wifes graduation from college. For the L, If you don't care too much about looks use A LOT of heat, like just short of bubbling the paint, and try to go steadily along with the roller.
    Few quick tips: Remove the fender liner. Seems obvious but many people try to roll with it in their. Use tin shears and cut all the tabs for the fender liner off the lip on the actual fender. Start with the 4 inches or so directly above (12 oclock postion) the hub. roll the lip back their, then work down both sides. The top, middle 5-6 inches is the most common rubbing spot when you dump or get crazy with offsets. Make sure you find at least 2-3 measuring points and wax pencil them on to the fender to keep the sides even. Also, quit while you're ahead (meaning keep checking the clearance with the tire everytime you think you've made some progress).
    My #1 rule: If you're looking for 3+ inches, go to a body shop, or expect buckling and wavy results.
    I'll post some pictures or a DIY someday when I'm ambisious.
    -colin
  11. Justin
    St. Paul, MN
    colin....no worries about this weekend, i really didnt mean this weekend anyways, just sometime.
  12. COBBsoobyStage1
    DT Minni
    Thanks for the advice. My dad owns a body shop, so I'll see what he can do. He's an oldschool - no replacement for displacement - kinda fella. If I get good results from him I'll be sure to let everyone know.
    running 17x7.5 53+ on a wagon. Works great as is but I'm looking to drop 2" in the front and 1.5" in the back. Should be interesting.
  13. Colin
    Moorhead
    man if your dad owns a body shop, go find some dodge dual pickup flares at a junk yard, cut them down and weld them on. thats what I plan to do when I have the money to switch over to GD rear end.
  14. COBBsoobyStage1
    DT Minni
    ha. wide body. I think all I'll need is about an inch at most.
  15. ShortytheFirefighter
    With that setup you shouldn't need to do much rolling at all, if any. You should be able to get 225's under there just fine with that offset. Even with that much of a drop you shouldn't have any issues.
  16. COBBsoobyStage1
    DT Minni
    Well that'd be great. I'll post pictures when I'm done.
  17. Justin
    St. Paul, MN
  18. Colin
    Moorhead
    Yeah, someday I'll be wide. Wide and ugly. But pretty has never been my thing.
