Anyone got an air compressor and a die-grinder?
Discussion in 'General Subaru Discussion' started by readymix, Nov 27, 2005.
  1. readymix
    Eloh, El
    Need to make some holes in things ;) Not sure on a date that I would need it yet. Anyone got a semi-portable aircompressor and a diegrinder that I could use to make holes in, say, a car hood?
  2. subaru4
    subaru4 New Member
    prison camp
    we have an aircompressor but not a diegrinder but my uncle might have one if u want me to check
  3. Dynapar
    Orono, MN
    i have a cordless drill, and some drill bits. did you get hood pins or something?
  4. LVT
    LVT Well-Known Member
    t3h f4sT
    fuji, fong, yia from here has air compressors they can get a hand of.
  5. readymix
    Eloh, El
    Hood pins...hmmm, no.
  6. Dynapar
    Orono, MN
    i see, i guess you will need alittle more then a drill.
    if you are unable to find anyone on here, i might be able to borrow/gain use of one from/at my buddys shop. but that is along ways away from you (other side of the cities almost)
    good luck finding a grinder, and good luck lining that vent up right.
  7. kickin_81
    kickin_81 Well-Known Member
    St. Paul
    I got an air compressor but no die grinder. Mine is 26 gallons big and runs 5.6 CFM @ 90 psi. If you want to borrow it, just let me know. It's a 2-person job to lift it.
  8. phi11
    Action Valley
    have both,
    I'll have to check the size of my grinder!!!!!
  9. subaru4
    subaru4 New Member
    prison camp
    we have a grinder if it will work
  10. readymix
    Eloh, El
    I need a die grinder, not a regular angle grinder
  11. subaru4
    subaru4 New Member
    prison camp
    do u want me to see if my uncle has one and if u can use his big air compressor
  12. subaru4
    subaru4 New Member
    prison camp
    or y dont u just go out and buy a air compressor at sears cuz u will probly use it again some other time
  13. readymix
    Eloh, El
    I don't have it in my budget to get an aircompressor right now. It is something that I will probably end up getting next year.
  14. subaru4
    subaru4 New Member
    prison camp
    do u want me to check with my uncle and see if he has a diegrinder. and see if u can use his big air compressor
  15. subaru4
    subaru4 New Member
    prison camp
    it also looks like it will be a fun project.
  16. WRX1
    Over there
    If you plan on cutting a hole in your hood that larger with a die grinder, it will take you all winter. I would use a jig saw/sawzall. From there you can use a die grinder to make it fit. I do have die grinders and bits, but everything I have wil take you months to cut out a hole like that. You could also use a cutoff wheel type, but you will still use alot of wheels. Oh ya, check out harbor freight, that always have die grinders on sale for like 9.99.
  17. hercules
    hercules New Member
    TC
    i use to have a air comp,die grinder and a jig saw until kongzilla burnt out my comp,lost my die grind...and my jig saw last time one of my buddy borrowed it to fraud his 240 lost it....
  18. subaru4
    subaru4 New Member
    prison camp
    i was just at menards and they had a die grinders there and they range from 15-35$.
  19. driftin240
    driftin240 Well-Known Member
    Out West
    Jason I agree with the using a sawzall. A die grinder will take forever on sheet metal even. I have a straight cut off tool, with 3" discs, but corners will still be hard to do.
  20. readymix
    Eloh, El
    ok, thanks for the pointers. I forget that my hood is steel not aluminum. I used to work in a metal shop, but it was mostly aluminum stuff, so we used die grinders alot for smaller cuts. Yeah, the steel hood will require a bit more than a die grinder. My only worry is that the sawzall will cause some pulling of the metal. We'll see what happens. I could always use a Sawzall.
  21. WRX1
    Over there
    well, you will want to use a fine tooth blade (probably 20 teeth per inch) and just let the saw do the work.
  22. subaru4
    subaru4 New Member
    prison camp
    the sawzall will probly bend ur hood u might be better off using a jigsaw. but do what ever u want to do its ur hood
  23. morganm
    morganm New Member
    I have a jig saw if you want to use it. Would prefer you came over and just used my garage to do it. You buy the blades :)
  24. readymix
    Eloh, El
    I have a jigsaw. But thanks for the offer.
