anyone reading this i still need some assistance. i have a 2004 wrx with a misfire in the #3 cylinder replaced the plugs and coil pack for that cylinder. my car will not read my cel code and tells me im good i need to get this running as its my only car can anyone help or have input? 952 201 3666
if you replaced the coil on that cyl AND the plug, there are only two other things it could be, a burned valve, or an injector, burned valves are more common however.
Injector would be the easier of the two. For the other you would need to pull the motor, take that side head off, replace the exhaust valve that is burned, and get a valve job.
whats the cost and timeframe for the valve? this is my daily driver and need it. know anyone who can do it? terrible to drive as is?
