Anyone have some driveway space and wrenches i can borrow.
Discussion in 'General Subaru Discussion' started by JasonoJordan, Jul 6, 2010.
  1. JasonoJordan
    Because my car sat for about a month my drivers side brake seems to be sticking and id like to get it freed up before i make the 130mile drive home later this week. So if anyone has a drive way and a jack with a set of metric wrenches or sockets id be more then happy to rent them out from you for a case of beer.
    Thanks.
  2. xveganxcowboyx
    St. Paul
    I have garage space in St. Paul if that's anywhere near where you're at.
  3. TSTRBOY2004
    I have a lift and air tools... At my house but I also live 40mins sth of the cities
  4. JasonoJordan
    I'm in edina but the 40min is no big deal I have nothing goin on this week. When will either of u be around?
    Sent from my Droid using Tapatalk
  5. xveganxcowboyx
    St. Paul
    I will be around most of the day.
  6. JasonoJordan
    big thanks to sean for the use of his tools and gurage. fixed the brake problem something must have either been not tight or had something wedged in there as i tool the brake off and put it back on and it stopped grinding. it has a little whisper to it when turning to the left but for the most part is fixed. Put my drive shaft bolt in but its still making a wirring noise under light load in 4-6th not sure what it is possibly carrier bearing im thinking. Also realized my passenger side tire lugs were loose as i had completely lost one. lucky for me sean noticed it and i tightened them up and proceded to drive down to O'Rilleys and spend 40 dollars on 20 locking lug nuts when i only needed one haha. Got the ac belt on but managed to break the tensioner.
  7. JasonoJordan
    also in the spirt of true subaru owner ship he would not accept payment in either beer or cold hard cash. +200 man points for sean.
  8. xveganxcowboyx
    St. Paul
    No problem man. It was good to meet you. I'm glad the car is (partially) fixed. ;)
  9. pcwerk
    pcwerk Well-Known Member
    rochester
    Sean's the MAN!
