anyone help me?
Discussion in 'General Subaru Discussion' started by 05subieGT, Dec 18, 2010.
  1. 05subieGT
    05subieGT Well-Known Member
    Im trying to install a cat back exhaust system in my legacy GT 2005 but the midpipe isnt going onto the stock dp because of a lip that is on the stock dp. this seems to be the next big step to get over and its really irritating. if anyone could help that would be awesome.
  2. me_john85
    me_john85 Member
    pictures? and what kind of exhaust are you trying to put on?
  3. 05subieGT
    i dont have pictures and dont have time really right now to do it but im putting a Gimmick Motorsports cat back on my legacy and im pretty sure the gap between the stock dp and cat back is supposed to be there?
  4. thunderdan1313
    thunderdan1313 New Member
    are u installing just the mide pipe or the whole cat back
  5. thunderdan1313
    i put that one on my lgt but i had a invid. dp im trying to think of the gap did u go with a 3inch? if so do u have the adaptor(do u need) so u can hook up a stock dp to a catback?
    where are u in the south meto ?
  6. 05subieGT
    the mid pipe right now then im getting the rest of the catback on after i get that pipe on
  7. 05subieGT
    i dont have the adapter because i didnt think i would need it necessarily i have a 3 inch catback and i have a 3 inch cattless megan DP but im waiting to install that till i get a tune, i thought the catback would be a simple bolt onn
  8. thunderdan1313
    it should be a simple bolt on
    trying to think of the lip on the stock dp
  9. 05subieGT
    there is a lip that went into the stock catback, and for some reason the 3 inch wont fit all the way over it ( im not sure if it is supposed to or not) i just want this thing on
  10. 05subieGT
    im in rosemount btw i didnt see that question
  11. thunderdan1313
    i do reme,ber with mine i found it easyer if i droped the dp off the hanger that was under the car and i had to do the top bolt first to get a good seal with no leaks
  12. JasonoJordan
    are u sure that they are both using the same flange. ones not using flat and the other using donught
  13. me_john85
    me_john85 Member
  14. 05subieGT
    its in and runnin very beautifully thanks for the help guys
  15. me_john85
    me_john85 Member
    how did you fix it?
  16. 05subieGT
    i found out that im dumb and the "lip" was a doughnut gasket so we just got some longer bolts, got it snug and put the rest on. no leaks sounds great. dp going on soon!
  17. JasonoJordan
    make sure u get a downpipe with donught style or it will start leaking soon. ask me how i know.
  18. 05subieGT
    think itll matter if the catback wasnt set up for a doughnut gasket? it was set up for a flat gasket that it came with. i just figured it would be easier to use longer bolts to snug it up to the gasket then when i switch the downpipe just use the flat gasket on it
  19. JasonoJordan
    it will blow out the gaskets i went through 3 gaskets in about 3 months before i welded on a flat flange 2 my downpipe
  20. 05subieGT
    you sure you just didnt over tighten the bolts?
