Anyone in Duluth with a Tactrix Cable or Accessport?
Discussion in 'General Subaru Discussion' started by h23, Feb 1, 2010.
  1. h23
    h23 Member
    Well as some of you know my WRX spun a bearing a little while ago, and I picked up an ej20g short block and brought the car back to stock. The issue is now that the car is stock, the ECU is still flashed with the VF34/STi Pinks map.
    I just need the car flashed back to stock to get it running safely, and so I was hoping someone on here could help me with a reflash back to stock and possibly a datalog to make sure everything is running right.
    Thanks a lot,
    Matt
  2. Shibbs
    Year?
  3. h23
    h23 Member
    It's a 2002
  4. JasonoJordan
    i have a taxtrix problem is im about 2 hrs west of u or so by grand rapids
  5. h23
    h23 Member
    Hmm I'll be driving through there on the 12th and heading back the following Monday. If I find someone who knows how to tune or use it locally I will let you know if it works for you.
  6. JasonoJordan
    pmed you a couple times
  7. h23
    h23 Member
    PM'd back. I think I've got it worked out thanks to JasonoJordan.
  8. JasonoJordan
    np just here to help
  9. matt_wong
    matt_wong Well-Known Member
    I got one, but my computer is busted right now.
  10. PhilSine
    PhilSine Well-Known Member
    My laptop is functional and could be used
  11. JasonoJordan
    well let me know if u need me to drive over when the time gets closer or not
