Anyone on mnsubaru have 19s ?
Discussion in 'Modifications And Maintenance' started by COBBsoobyStage1, Apr 4, 2007.
  1. COBBsoobyStage1
    COBBsoobyStage1 New Member
    I'm looking at getting some 19s on my wagon. I also have a set of sports springs in transit from cobb. Anyone have this or a similar setup? If so, any issues? Pictures please!!!
  2. Sogonerg
    Sogonerg Anteater
    WRxboy2003, but he has a sedan
  3. TSTRBOY2004
    yep.... I have plenty of clearance and no issues but I have a sedan...
  4. COBBsoobyStage1
    do you have new/different springs? I believe the cobb springs drop the front 2in and the back 1.5in
  5. ShortytheFirefighter
    What is the offset on the rims you are planning on running? What size tires? Do you have your fenders rolled? All of this is going to play a part in how well it'll work for you.
  6. TSTRBOY2004
    I have stock springs... cut a coil out of the front to drop the front to level with the rear....
    I want to get new struts and cobb springs or somehting in the future bit stock right now...
  7. COBBsoobyStage1
    35 offset 215 tires
  8. ShortytheFirefighter
    What width are the rims?
  9. bummpy
    bummpy New Member
    g g gg g ghetto ghetto!!
    haha.
    You should probably get some replacements in there. Although you probably don't autocross or anything, so it's probably not that big a deal.
    At least it's not as bad a holding the torch to it... I think?
  10. COBBsoobyStage1
    rim width = 8J ...
  11. ShortytheFirefighter
    Your wheel bearings aren't going to like that too much and there's a good chance you will end up rubbing with that setup, not to mention that a 215 width tire on an 8 inch wide rim is a bit of a stretch. Optimum offset on an 8in wide rim is +43 to +47, so that +35 is quite a ways out from that.
  12. TSTRBOY2004
    it may be ghetto... but it sure aint 4wd height....
    we never touched the comfort coils, so the ride NEVER changed.... and it DOESNT bounce like a HONDA on bumpstops....
    You wouldnt even know with the ride or the look that it had 'chopped' springs... but yeah it may be ghetto in some thoughts but it was cheaper.. ie $0 for me to drop the 10inch lift out of the front end... try stock wheel well gap and 19s not a good look... ha ha ha
    who cares.. your ghetto if you chop a coil, your ghetto if you run anything over 17in, apparantly by some opinions on here, and most those guys who comment do the roughest hack job work on their own cars.. ha hah so I dont care what people think... unless you go outrageously ugly on your mods (RAY) jk... then who cares..
  13. readymix
    you WILL rub with that setup. Just so you know. Your wagon fenders wont accomodate that offset at that width.
  14. COBBsoobyStage1
    what does that even mean?
  15. carl
    it means your wheels won't fit without fender mods
  16. ShortytheFirefighter
  17. carl
    anyone know where i can find the specs on the wheel bearings subaru uses? i've always wanted to run some bearing stress calculations on them (they use angular roller bearings i assume).
    215 on an 8" rim - what is this vdub land? or is this a drift car? :laugh:
  18. ShortytheFirefighter
    VW look was the first thing that popped into my head too. 8in is about .5in from the max recommended for a 215 width tire IIRC.
  19. COBBsoobyStage1
    damn... Its just that I found a really good deal on some awesome 19s... oh well. back to 17/18s I go
  20. carl
    i found a really good deal on used underwear. doesn't mean i'm going to go for it
  21. COBBsoobyStage1
    That's why I'm asking *fool*
  22. Scuba Steve
    yeah, go with 17's....better performance and still looks good
  23. carl
    i can tell you have a temper and probably a marginal sense of humor
    i'm just kidding with you man, lighten up
    plus, what do i know about rims? i had chrome rims on a 240sx :laugh:
  24. COBBsoobyStage1
    I'm just giving you guff...
  25. carl
    touche salesman
  26. Sogonerg
    Sogonerg Anteater
    whose the salesman, punk...:lollollollol:
  27. carl
    i guess that would be you. or is it?
  28. Squiggly
    Squiggly Squiggly
    17's!!USDHG
  29. COBBsoobyStage1
    I'm just trying to be cheap. I have a bent rim and am planning on replace the factory set. I want to get something fun but don't want to drop 2k on rims/tires. Anyone have some good sugestions for something I could get for 1k?
  30. -_-_-_204
    -_-_-_204 Active Member
    rpf-1 17x8 is the best wheel for 1k
  31. Squiggly
    Squiggly Squiggly
    rotas and enkeis are pretty nice wheels for the money. go onto edgeracing.com and tirerack.com and pick out some options. if u get stuck between a few come back, post a picture of your car and your wheel choices and we can help u out. otherwise try and make your own choice. its your car
  32. Sogonerg
    Sogonerg Anteater
    PM Shorty he works at discount tires...he'll hook it up for ya
  33. fusion guy
    fusion guy New Member
    <~~~~~~~~~~~~~~~~~~~ 235/35/19's on the fusion sti and yes we do rub a lil on the rear fenders mainly when we hit a good size bump
  34. readymix
    But that's an STi, not a wagon.
  35. COBBsoobyStage1
    ok, so what width should I look for. Good advice on the site btw.
  36. readymix
    7.5 would be the widest width I would go with for a wagon. That may still require some fender rolling. If I had a wagon, I wouldn't go larger than 18x7.5. And I'd keep the offset between 45 and 52
  37. ShortytheFirefighter
    If you look around for used 2004 STI wheels you'll have either a +53 or +55 offset (I can't remember the exact one right now and I'm at our Nissan store so I can't look it up) and you can run a 225/45/17 without rubbing and it'll keep your wheel bearings happy. The Rota SDX's are a wagon specific offset in 17x7.5 +53 and you can run 225's without rubbing. Otherwise, you're going to be very limited as to what you can run tire/rimwise, it's all in the widths vs offsets, and (to make things even harder) a 225 from one manufacturer may be wider than a 225 from another, same with 215s. There are a couple of wagon specific threads on Nasioc regarding suspension and wheels that you'll want to check out as well.
