AP question
Discussion in 'Modifications And Maintenance' started by 02blubru, Jun 14, 2006.
  1. 02blubru
    Norwood Young America
    If I buy an AP for my 02 WRX stage 2 and lets say 2 years down the road I buy an STi, would that same AP work as long as I unmarry it from my 02 and upgrade the maps on it?
    Thanks
    Bill
  2. Dizmal
    Dizmal Well-Known Member
    In mah Forzda, yo
    Short answer. No.
  3. 02blubru
    Thanks, did not think so, but thought it was worth asking.. Thanks again Dizmal
  4. Dizmal
    In mah Forzda, yo
    No prob. But atleast the resale value is hgh so hopefully in 2 years you could still sell it for ~$5-400 and buy a STI AP.
  5. 02blubru
    True, very true..
  6. 02blubru
    another question along the same lines..
    If I buy an AP stage one and I make my car stage 2 what needs to be done? Just up load stage 2 map onto my ap then my car? Just trying to get a feel to how these babys work.
    Hopfully by september I will be stage 2...
  7. Sogonerg
    Sogonerg Anteater
    Earth
    TBE...But since u a Catback, just get a DP. If you want to push it further, upgrade the stock up-pipe.
  8. 02blubru
    ^^^ did not answer my question about AP's, good input just not an answer to the question..
    I will be PMing you when it does come time to buy and AP, I hear you the man to see for those...
  9. Sogonerg
    Sogonerg Anteater
    Earth
    That's what you need for a Stage 2 setup...And yes, you can DL the stage 2 and then into your car, and yes it is that easy...The AP's I receive and sell will have stage 1 and 2 pre-loaded already as well.
    PM me whenever your ready...depending on when you buy the AP's maybe on backorder...
    Stage 1 (Bone Stock)
    Stage 2 (TBE)
    Hope this helps...
  10. Dizmal
    In mah Forzda, yo
    Yeah, the AP's come preloaded with 4 basemaps and 6 real time maps.
    The initial base map is what you upload the first time and takes a while. The real time maps take about 10-15 seconds to upload and don't hurt the flash memory of the ECU.
    So, you could install the Stage 1 basemap right away and then when you finish the TBE you could flash the Stage 2 real time map. Make it a little easier on yourself.
  11. Sogonerg
    Sogonerg Anteater
    Earth
    Depending on where you buy your APs. I know gruppe-S doesn't come mapped. I get mine directly from Cobb which will have stage 1 & 2 91oct. or 93 oct.
  12. Sogonerg
    Sogonerg Anteater
    Earth
    When are you getting one?
  13. Dizmal
    In mah Forzda, yo
    You fool.
    I've had one since January! I've only told you that 3 or 4 times now...:crying::eek:wned:
  14. Sogonerg
    Sogonerg Anteater
    Earth
    ^3 times...Stop exact-gerating haha...
  15. WRX1
    Over there
    You just need to remeber that when you do this, you are not getting the full benifit on the stg2 maps. There are other paramters that the stg2 maps change that don't get upgraded when you flash the real time maps.
  16. Dizmal
    In mah Forzda, yo
    Hrm, did not know that.
