Who does tunning in the st. paul area? Will I get a better setup than AP stage 2, with 91 octain ? thanks mac-leg
if i remeber Russ (wrx1) does street tunes right? and if you went to DB you would be on the dyno.. i think that iam going to get a tune by russ sometime soon. i might only get 5-10 hp's but at least it will run good.
Yep, I can do street tunes. Just a note, on stg2 cars (wrx and sti) there isn't a whole lot that you can get out of them. Basically you will run out of gas. What I can do is lean out the afr to get a little more head room in the injectors and then turn up the boost a bit. Basically you should be able to pick up around 10whp or so. Russ
