AP v2 Launch control??
Discussion in 'Modifications And Maintenance' started by Se7enrex, Jan 31, 2008.
  1. Se7enrex
    Se7enrex Well-Known Member
    All over Slingin' Parts for the Hungry
    anybody played with this yet or are currently using it??
    thoughts, concerns, or just to say hi?
  2. Rexwagon
    Rexwagon Well-Known Member
    Fargo, ND
    just saying HI
  3. mnstilynwrx
    mnstilynwrx Well-Known Member
    Minneapolis, MN
    Hi. no but i thought that was a really cool idea. i have seen a few videos of it looks like it works well. obviously it has it's pro's and cons. dont do it at every stop light type of thing, but i say go for it AWD launche's for the WIN!!!
  4. tux121
    tux121 Well-Known Member
    Champlin
    oh i want that......
  5. Nuke
    Saint Paul
    blah, learn to launch
  6. Taras
    Taras BANNED
    Saint Paul, Minnesota
    what does launch control does anyway?
  7. Nuke
    Saint Paul
    Ever launched your car before?
    LC is for suckers who can't :laugh:
    But seriously, look up Launch Control.
    There's a few threads on nabisco about it.
  8. tux121
    Champlin
    Nuke I told you already I suck at launching haha. +1 for the outstanding step-2 sound also.
  9. Taras
    Taras BANNED
    Well i tried, my clutch slips.
  10. tux121
    Champlin
    my best launch was a damn 1.889 60ft
  11. Shibbs
    I don't like launching hard. I roll into it to give the Fail-wheel-drive honduhs a chance, then still walk away. :D
    That being said, I still wouldn't mind launch control if I did ever track my car.
  12. esperunit
    esperunit Well-Known Member
    Paris, 7eme Arrt.
    I have it, hope to never use it.
  13. 02blubru
    Norwood Young America
    Hi Will
    :wavey:
  14. Treylizardo
    Treylizardo Active Member
    St. Paul
    I know some 07 STI's tuned with LC enable have run into compression issues.
  15. Dream
    south
    I loved it. Allowed me to launch with boost.
  16. Moleness
    At work or in the garage
    Mmmm...with boost. This only works with the AP V2, right? That sucks.
  17. Nuke
    Saint Paul
    UTEC has a LC system
    OpenSource, one has posted his patcher, but a few have said to got it to work, but haven't released it.
    There is another kit you can buy to give you LC
  18. Bullwinkle
    Saint Paul
    I'm going to say that there is a high probability this was due to the tune, not LC. '07 STI's are notoriously hard to tune due to the higher flowing heads/turbo and injectors running at high duty cycle.
  19. Nuke
    Saint Paul
    I believe Jorge does not want to enable LC on the 07 STI, because of it causing problems.
    Some tuners have enabled it on some, but I believe they ran into problems.
  20. StatGSR
    StatGSR Well-Known Member
    Duluth/Lutsen
    2 steps ftw!
  21. idget
    falcon heights
    Same here.
    He enabled it on mine. Albeit with a strong warning that he holds no responsibility if I use it and car assplodes. It's probably only on there bc that's the base map he's working off of.
    Seriously tho, launching these cars isnt that difficult. Learn some clutch control and practice soft launches on low traction surfaces... slip the clutch faster if you smell clutch and slip it slower if you feel driveline shock.
  22. Dream
    south
    I was running a UTEC at the time.
  23. webcrawlr
    webcrawlr Well-Known Member
    minneapolis
    I think it's so wanted because LC builds boost. You can't do that just launching on your own.
    Spot on. Some of the national tuners have even re-tuned the 07s they did at no charge to help correct some of those issues.
  24. wrxpeed
    wrxpeed CobraPeed
    Maple Grove
    I used to use it when I had the UTEC in the WRX. Was able to build 12 lbs of boost on the line. It was more for fun at the stoplight to confuse people. One time I lined up in a 3 way with a new GTO and Rustang and started boosting it. The looks on their faces were priceless :eek3:. I never launched it at full boost. 1-3 lbs is more than enought to spin all four and not shock the drivetrain.
    If you do use it make sure its an injector cut instead of ignition cut limit. I messed with the ignition cut just for the flames and ended up fouling all my plugs :hsugh:.
  25. Hallywood
    Hallywood Well-Known Member
    Bloomington MN
    forget LC, get anti-lag setup :roll:
  26. Paul Revere
    In the land of ice and snow.
    Ask Mike Wray what happens when you run anti-lag on a car that can't handle it :ugh:
  27. Hallywood
    Bloomington MN
    I was totally joking, but I'm sure it wasn't good
  28. idget
    falcon heights
    right. My response was directed towards tux and well, the rest of us that will never really need it and are better off not using it bc for the most part...
  29. driftin240
    driftin240 Well-Known Member
    Out West
    If you don't have a LARGE turbo like Dream, and others... :cough: Fobia :cough:, then you shouldn't need it to launch with boost. Simply revving the motor in pulses should get the turbo compressor spinning pretty good, and allow you to launch with some tire smoke. It takes practice, but I've spun all four with some smoke on a stock TD04. Tuned by WOTV, of course...
  30. dipp
    dipp Well-Known Member
    Fobia's on the weekends.
    <----- master of the launch w/12-15lbs of boost. smoke all 4 tires for about 10ft and gone like the wind. launch control = push the brake to the floor and the gas to the floor then lift off the brake.
