Aria: 2008 STI Built/Cams/GTX30r/AST/Enkei/E85
Discussion in 'FS: Cars, Motorcycles, Boats' started by ViktorVaughn, Sep 24, 2012.
  1. ViktorVaughn
    ViktorVaughn Active Member
    Project: Aria the White Wolf
    Note: I will be out of town Monday September 25th-Friday the 29th. Emptied PM box.
    Car: 2008 Subaru Impreza WRX STI
    Color: Aspen White(The MOST beautiful GR color)
    Miles: 41,673 (420 on motor, 440 on brakes and clutch)
    Price: $33,897.31 OBRO (No rush here)
    I have no problem facilitating shipping, have experience with doing so.
    Partial Trades Accepted(will consider others):
    -Triumph Street Triple (Triple R Preferred)
    -Other Naked street bikes
    -Snow beater/destroyer (Audi B5 A4, Older Impreza/forester/legacy, must be manual)
    -Volk TE37 wheels 5x114.3 18x9.5 +22 - 18x10
    I'm going to miss this one, but I think the time has finally come to end this project to help free up funds for a house. Its been another great experience, and as anyone knows these endeavors don't end until sold. I still have a running list of things I will be doing if it doesn't sell. If you are interested please send a PM or post your question in the thread, more than happy to provide detailed information.
    This car is a monster, it's scary every time I drive it no matter how much I think I've acclimated. The engine and transmission mounts are nearly solid, and transmit every noise you didn't know Subaru's make right into the cabin. The suspension is actually relatively comfortable considering how much more planted it is over the stock setup. That being said it does give you very accurate feedback of the road surface. Despite the power currently being fuel system limited, 500whp+ with great response(E85) is terrifying for a street car. It will break traction in second gear pretty easily. For this reason there will be no joyrides or driving the car unless you have some form of cash in hand. This will be discussed more in depth with interested parties.
    With a few simple changes it could be made much more comfortable. Softer spring rates, Group N or stock mounts, and a progressive 91-93 octane tune would be all it really needs. By the same token its not far from being a fun track car, would need some form of camber adjustment in the rear and an aftermarket radiator. For me the joy has been periodic terror, it works well as is!
    Quick Overview of Condition:
    Transmission and Differential: Fluid every 7500k since I've had it using Extra-S(ownership from 20k miles onward).
    Engine: Amsoil Break in OIl SAE30 used for the first 3 changes(30 minute warm up, 50 mile, and 300 mile). Next change will be Brad Penn 10w-40 at 500 miles.
    Brakes: Just replaced pads and rotors with the Girodisc/PMU setup, Fluid could be changed as its been about a year now.
    Suspension: Bushings greased 3k miles ago, sway bars and related brackets were powdercoated while I was rebuilding engine. AST4100 coilovers have 3200+ miles on them.
    Clutch: Disc and flywheel installed at the same time as most current motor build, pressure plate was re-used and has 1400 miles.
    Body: A few minor rock chips and paint has come off the inner and a bit of outer rear fender from aggressive tire setup. This has been touched up. Last I counted there are 4 very minor dents that could easily be removed via PDR, barely noticeable on white. Other than that it's only seen two bucket washes or spray rinses. I err on the side of having a dirty car over sub par washing or the aggressive citrus/acid based touchless washes. Periodically clay barred along with the application of sealant and wax. I have list of products used for any detailing nerds. The front bumper is from the 2011+ WRX/STI, and was done after the car eat a Raccoon cracking the lower portion of the original bumper. It has also eaten an owl that did no damage aside from splattering blood across the hood and headlight. This is how it gained the name White Wolf. Animals beware. The car has only seen one relatively mild Minnesota winter, before that it was a southern car.
    Wheels/Tires: One very minor scratch on one wheel, a few tiny chips, stickers are peeling slightly. Zero curb rash. I have a second set of stickers if you want them to look near perfect. The wheels have been used minimally, the Hankooks are the only tires that have ever been mounted. These have 70% of their usable life left.
    Interior: Good condition overall. A few small scratches in the lovely Subaru plastic and the accent stitching down the center of driver seat bottom was cut. Still have to get photos of this.
    The work has been done by myself and a local group of Subaru Gurus known as NF Performance, or Nuke and Fuji Performance. Check around the forum, they are great guys who know Subaru's. This is not the first time I've built the motor. After the stock motor went I built it mildly and the incorrectly produced A1 Technologies MAP H11 studs allowed the head to lift at 29psi. Not surprising really. I went with a simple rebuild and had a shop polish the crank. The journals were out of round allowing clearances to be inaccurate. Bearing noise after 15 miles. Decided to do it a little better and upgraded a few more things and redid everything. For the builds I was hot tanking everything I could, hand cleaning some such as intake AVCS gears, charge piping, intake mani, TGV's, and replacing what I couldn't(Oil pan, pump, Oil cooler, Exhaust AVCS gears…). So far this build has 418 miles on it, 315 were break-in before the tuning. I used a mixed break-in method of slow pulls to 5000rpm allowing the engine to slow itself. During normal driving I have altered the revolutions as much as possible. We made 515whp/450wtq at just 25psi per VD which compares very closely with MAPs Dynojet. This is fuel system limited, it will need a larger pump/double pump/surge tank setup with injectors in the 1600-2150cc range. With these upgrades on E85 it should make a healthy 500wtq+/550whp+ at 28-30psi. If you are not near E85 this fuel system is enough for 93/100/C16 tuning. I have a lot of my receipts, some are sure to have gone missing from moving a few times. Lots of stickers/decals too.
    Going to forget something, here goes…
    Engine:
    -Have blueprint
    -All Internals have been balanced
    -New Block halves
    -Torque plate honed
    -CP Pistons(99.5)
    -CP Wrist Pins (WPC Treated)
    -Crower rods(Resized to tight FSM specs)
    -2012 Nitrided Heat treated Crankshaft (machine shopped checked that it was straight before dynamic balancing)
    -Cosworth Main Bearings Standard Clearance(WPC Treated)
    -Cosworth Rod Bearings Extra Clearance .0018-.0020 as measured(WPC Treated)
    -Cosworth Head Gaskets .78mm
    -ARP Custom Age 625+ Studs
    -KillerB Pickup
    -New oil pan
    -11mm Oil pump (WPC Treated Internals)
    -Mocal Oil Cooler and Adapter Plate
    -Deleted and Ported TGVs(Done by MAP)
    -Gates Timing Belt kit including Water Pump
    -Grimmspeed Lightweight Crank Pulley
    -Crawford AOS
    -Torque solutions Motor Mounts
    -Deleted Secondary Air System
    -Omni 4 Bar MAP Sensor
    Heads:
    -All work performed by MAP
    -Deck/Resurface to high RA
    -5 Angle Radius Valve Job
    -Supertech Nitrided +1 Intake Valves
    -Supertech Inconel +1 Exhaust Valves
    -Supertech Guides
    -Supertech Seals
    -Supertech Buckets & Shims
    -GSC Beehive Springs
    -GSC Titanium Retainers
    -GSC S2 Camshafts
    -New Exhaust AVCS Cam Gears
    -Cleaned Intake AVCS Gears
    Turbo & related:
    -Perrin Rotated GTX3076 .82 AR Kit
    -Perrin FMIC (Wrapped with Reflect-a-gold)
    -Forge BPV
    -Tial MV-R Wastegate(Full spring kit)
    -No Catalytic Converter
    -All Exhaust components painted with VHT Ceramic Exhaust Coating then wrapped in DEI titanium
    -Hybrid Boost control
    -Grimmspeed EBCS
    -Grimmspeed Manual Boost Controller
    -Litespeed header (Swaintech White Lightning Coated and ported)
    -AEM Wideband with RS-232 in glove box for logging
    Fuel:
    -FIC 1100cc Injectors(1300cc at 55psi Base)
    -Deatschwerks 300lph Pump (Hardwired using relay)
    -Fuel Lab Fuel Pressure Regulator (Base Pressure 55psi)
    Drivetrain:
    -Clutch/Flywheel Assembly has been balanced
    -ACT 6-puck Sprung Disk
    -ACT Extreme Duty Pressure plate
    -ACT Streetlite Flywheel
    -Cobb Short Shift kit
    -Cobb Shift Knob
    -Shifter bushings
    -Torque Solutions Pitch Stop
    -Torque Solutions Transmission mount
    Brakes:
    -Grimmspeed Master Cylinder Brace
    -Project Mu B-Spec Pads
    -GiroDisc 2 Piece Rotors F/R
    -Motul RBF600
    Suspension/Wheels:
    -AST 4100 Coilovers(favorite modification)
    -Hypercoil F8k/R10k Springs
    -AST Tender Springs
    -Vorschlag Camber plates
    -Whiteline Front 24mm Adjustable Sway Bar (Powdercoated)
    -Whiteline Rear 22mm Adjustable Sway Bar (Powdercoated)
    -Whiteline Rear Sway Supports(Powdercoated)
    -Whiteline Front Control Arm Bushings
    -Whiteline Anti-Lift Kit
    -Whiteline Steering Rack Bushings
    -Whiteline Rear Differential Inserts
    -Whiteline Rear Subframe Inserts
    -Enkei NT03 18"x9.5" +27 Touge Factory Limited Edition Flat Black
    -Hankook RS-3 275/35-18
    -Worn set of Yokohama S.Drive 255/35-18 (not mounted but usable)
    Misc:
    -Cobb Accessport
    -Kenwood DNX-7180 Navigation system
    -Ipod integration
    -Bluetooth ready with Mic above steering wheel
    -2011+ Front Bumper
    -Optima Yellow Top Battery
    -35% Window Tint
    -JNA Front Lip
    -ARK GRiP Catback Exhaust system(cut off neck down section and welded 3" flange)
    -Perrin Coolant reservoir
    Onto some photos:
    SkeetsWisconny likes this.
  2. ViktorVaughn
  3. 03subyR
    03subyR Well-Known Member
    Wow, very beautiful car.
  4. xluben
    It's a shame to see you're selling! This is such a well thought out and executed setup! It just needs a little more fuel and it could be a monster on E85.
  5. Nuke
    April fools in September?
  6. blackzpremacy
    blackzpremacy Well-Known Member
    wow.... just wow...
    blak04wrx likes this.
  7. Mitchum
    Mitchum Well-Known Member
    what he said!
  8. ViktorVaughn
    Will be sad to see it go, but there will be other projects in my future. Variety is the spice of life or something like that. It will be a riot for whoever buys it. I have a feeling if I keep it it won't have in interior by the end of the year...
    BugIedIzzy likes this.
  9. BroCo
    BroCo Moderator Staff Member
    I want this!
  10. Musashi
  11. kongzilla
    kongzilla Well-Known Member
    This is a used car that I do not mind spending 30k on.
  12. GiMp
    GiMp Well-Known Member
    Just talk to the wife to get permission :)
    BroCo likes this.
  13. happyfeet
    happyfeet Member
    sad to see this go
  14. ViktorVaughn
    Thanks for the compliments everyone.
  15. AspitFire
    Take that Lsx Rx-7 trade on nasioc! looks like a sick car.
  16. idget
    No no no, if a guy from az with an s2k cr trade gets a hold of you work something out with him. That car is practically showroom. Really good guy too.
  17. ViktorVaughn
    That S2000 CR is way too nice for my purposes. That being said I do see an F22C in my future, preferably with a Full Race manifold attached to a spinny thing.
  18. attorv
    attorv Active Member
    wow my dream car right there. GLWS!
  19. ViktorVaughn
    Someone local buy this before I ship it across the sea to Rotterdam! Would love to see it around once in awhile.
  20. BroCo
    I want this so damn bad.
  21. tangledupinblu
    Who doesn't Bro!? It's badass.
  22. Musashi
    You guys should all pitch in and purchase this thing as a joint ownership! Come on it'll be fun! ;)
  23. tangledupinblu
    I call weekends!
    Musashi likes this.
  24. Musashi
    I call Mondays! :coffee:
  25. TMF
    I call every track day of the year! (I'll drive mine the rest of the days).
    But seriously, this car is like the evil twin of mine. If you ever decide to part out your suspension, let me know!
  26. ViktorVaughn
    Price for MNSubaru members if sold before winter is $32k!
  27. BroCo
    Someone buy this to eliminate my temptation!!!
  28. Nuke
    Dude, just buy it and sell yours. seriously.
    Then you'd save $ and spend $. It's a win win situation.
    BroCo and blackzpremacy like this.
  29. Tash
    Tash Well-Known Member
    Save money on a build and just sell yours
  30. BroCo
    Trust me, it has been on my mind since this went up for sale.
    TickTack and Musashi like this.
  31. Musashi
    I think Sifu BroCo may have doubts he may not be able to handle all the powa....but don't worry, that's what we're here for. Besides you're in your prime and we don't want you looking back and making regretful excuses. ;)
    I shall make a huge contribution should you reconsider! :coffee:
    BroCo likes this.
  32. ViktorVaughn
    Sold, goodbye friend.
  33. BroCo
    Congrats on the sale. I seriously considered purchasing this. Did it go to a member on the Forum?
  34. ViktorVaughn
    Nope its moving south to North Carolina, a very nice Subaru enthusiast is buying it. Its going to be a weekend mountain roads destroyer.
  35. xluben
    Congrats on the sale! Sad to see it go :(
