August Car Of The Month- Voting
Discussion in 'General Subaru Discussion' started by Scuba Steve, Jul 30, 2007.
August Poll
Poll closed Aug 1, 2007.
  1. TARAS
    3 vote(s)
    7.3%
  2. TANGLEDUPINBLU
    4 vote(s)
    9.8%
  3. TBONE
    24 vote(s)
    58.5%
  4. STOOOO
    10 vote(s)
    24.4%
  1. Scuba Steve
    Alright, we have Taras, TBone, Tangledupinblu, and Stoooo. Good luck!!!
    TARAS
    Occupation: Foreign Student and ITS Help Desk Consultant
    My Car: 2002 WRB Impreza WRX
    Specs:
    * Stage 2
    * TurboXS Steathback Exhaust with 4" downpipe
    * OpenECU reflash
    * Samco Intercooler pipe
    * ROTA SDR gold rims
    * Tein Basic coilovers
    * Kartboy Shortshifter
    * Almost forgot:JDM sti Zero front grill
    Plans for Mods:
    * HIDS
    * Maddad Gauges in the bezel
    * New Tries
    * Bigger turbo sometime in far away future.
    I love the car to death, the best part is when you feel the turbo kick in and that it has 4 doors.
    ________________________________________________________________
    STOOOO
    Me: Stuart Powell, IT God, wonderful husband and father, wannabe race car driver
    The car: Igor, 2001 Impreza 2.5RS
    Likes: Stretching his legs on the AutoX course, where he's much more talented than the nut behind the wheel
    Mods:
    Power
    Ganzflow CAI
    K&N Filter
    Borla Header
    Tanabe Racing Medallion CBE
    UR Crank Pulley
    Magnecor Plug Leads
    NGK Copper Plugs (The JIS sized ones so the Magnecors don't pop off)​
    Suspension
    Koni Sport Inserts
    Eibach Pro Kit Springs
    PDE Camber Plates
    STi CF Front Strut Bar
    STi Grp N Rear Strut Tops
    Whiteline 22mm FSB
    IPD 18mm RSB
    Whiteline Rear Lateral Links
    Whiteline Rear Toe Lock Kit
    Whiteline Rear Diff Front Bushings
    Super Pro Poly Rear Trailing Arm Bushings F/R
    Rota G Force, Flat Black, 17x7.5 +48
    Falken Azenis RT-615 225/45-17​
    Driveline
    STi Grp N Engine Mounts
    STi Grp N Pitch Stopper
    STi Grp N Transmission Mount
    Kartboy Short Shifter
    Kartboy Knuckleball Shift Knob
    Kartboy F/R Shifter Bushings
    TiC Pivot Bushing
    Whiteline Tranny Crossmember Bushings​
    Brakes
    Goodridge Brake Lines
    Racing Brake Slotted Rotors F/R
    Hawk HPS Brake Pads F/R
    ATE Super Blue Brake Fluid​
    Dress Up
    Crystal Clear Corners
    Clear Side Indicators
    Blacked out Front Indicators
    Black Lower Vents
    Black Mesh Foglight Covers
    Blacked Out Tail Lights
    Red Lug Nuts​
    Other
    STi Pedal Covers
    Trunk Monkey
    Kartboy Battery Tie Down
    Kartboy Red Exhaust Hangers
    JVC HD Radio Head Unit
    Red Line fluids in engine, tranny, rear diff and PS​
    Future
    Ground Control Coilovers 400f/450r (I finally picked spring rates and ordered them)
    Whiteline 24mm Adjustable RSB
    Whiteline HD RSB Mounts
    Perrin F/R Endlinks
    Whiteline Front Control Arm Offset Rear Bushings
    Super Pro Poly Front Control Arm Front Bushings
    Super Pro Poly Rear Diff Rear Bushings
    TC Sportline Rear Strut Bar
    TiC Front Shifter Bushing Kit
    Paranoid Fabrications Grounding Kit
    Aggressive Jeff the Alignment Guy alignment once the coilovers are installed
    Crystal Clear Side Indicators​
    Thanks to Dan Engle for the picture. Higher res versions of his pictures can be found out on www.superawesome.net.
    Attached Images[​IMG]
    tBoNe
    MY02 Subaru Impreza (ShAd0wZ)
    St. Louis Park
    German Citizen. 9 years US immigrated. College Graduate from Brown College as a Graphic Design Multimedia. Occopied as a Technicial Engineer as well design freelances.
    Engine
    V7 JDM STI Spec-C EJ207 Motor
    Deadbolt Superzilla 49 Turbo (off the shelf, 7cm housing)
    TiAL 38mm External Wastegate
    Modified Injectors Flowed to 720cc
    Walbro 255 Fuel Pump
    EcuTek tuned by @ Clark LSE Performance
    Apex'i AVCR – Electronic Boost Controller
    Perrin Front Mount Intercooler
    Perrin Big Maf Intake
    Perrin Turbo Inlet
    Invidia Downpipe
    Gruppe-S Uppipe w/ welded EWG Flange
    HKS Exhaust Manifold
    Thermo-Tec Heat Wrap
    HKS Carbon TI Exhaust
    Tial Blowoff Valve
    Perrin Crank Pulley
    Power Enterprise Timing Belt
    Grounding Kit
    STi Radiator Cap
    Samco Auxiliary Hoses
    Throttle Body Coolant Bypass
    ZeroSports Radiator Shroud
    Kartboy/N-Group Exhaust Hangers
    Aquamist 2D Methanol Inj
    Crucial Racing Thermostat
    EVANS NPG Waterless Coolant
    IA Performance AVCS Wiring Harness
    Factory Spec-C Ecu Launch Control
    Transmission
    V7 JDM STI 6spd (JDM 5/6th tighter gears)
    ACT 6 puck hub sprung w/Extreme Pressure Plate
    SPT Lightweight Flywheel
    Kartboy Shifter Bushings F+R
    SS Clutch Line
    STI JDM rear ring and pinion kit
    Suspension/Brakes/Wheels
    Tein Flex Coilovers 10kg/8kg
    Cusco Front and Rear Strut Tower Braces
    Perrin Rear Sway Bar
    Stoptech 332x32 2-Piece Front Big Brake Kit
    Stoptech 328x28 2-Piece Rear Big Brake Kit
    Axis Ultimate (Street Pads) (Brand New)
    Enkei RPF1 "Gold" Wheels 17x8 w
    Yokohama Advan Neova AD07 Tyres
    Brembo DOT 4 Racing Fluid (New)
    Interior
    Kirk Racing Roll Bar
    JDM V7 gauge Cluster 8k redline
    2005 Sti Headunit
    HKS Turbo Timer
    Autometer Cobalt (EGT, Boost, and AFR) Gauges
    Gruppe-S Carbon Fiber Gauge Pod
    Viper 790XV Alarm w/ Remote Start and Auto Window Control
    Boston Acoustic S65 + S55 Speakers
    Takata 5pt Harness
    Bride Brix II Replica Seats
    12000k HID
    Custom Black Carpeted Interior
    2004 WRX Door Cards
    Exterior
    Wingless with Tein Stickers covering spoiler holes
    Sti Replica CF Side Markers
    Sti Replica V1 Front Lip
    Sti Replica Front Grill
    Painted Fog Covers
    Painted Side Skirts
    Baked/Painted Headlights
    Hella Horn
    Tangledupinblu
    Brooklyn Park
    Occ.:Construction
    Car:2002 Subaru WRX 2.0L
    "Work in progress"...:roll:
    --ProDrive Stage 2 Kit=
    (silicone y-pipe, catless third pipe replacement, Prodrive re-flashed ECU)
    --SPT intake w/custom built 'SPT Short Ram Air Induction Box'(Thanks Grimmspeed!)
    --STi Axle back & Spoiler
    --Rota GRA 17inch rims/Gunmetal grey on
    Bridgestone Potenza's 225/45 (summer)
    --ASA 17inch rims in Gold on
    Blizzak LM-22 Run flats 225/45(winter)
    --35% Gunmetal Grey window tint
    --Custom Interiorz
    --Custom two tone headlights-Grey/Blue
    *Weaksauce I know, stage 2 coming soon.*
  2. Scuba Steve
    Damn Taras, you would've never entered this contest with that chop shop Subaru you almost bought...congrats on the right move!
  3. ej20
    ej20 Well-Known Member
    man...when will my modification list be as long as yours tbone?...I'll never ever gonna get there. Now thats what I call a professional post of the first pic you got there. I love it.
  4. Taras
    Taras BANNED
    Thanks i know, and i am so happy and lucky that i got the one i got. In part a huge thanks to a lot of people here.
    No way i am comming anywhere near the 2nd or 3rd place:roll:
  5. jubella2
    jubella2 GC8 FTW
    Hard choice this month
  6. Taras
    Taras BANNED
    someone voted for me, who?
  7. wall of tvs
    All are very nice vehicles!
    Props to all.
  8. Bielke55
    <--- sTOO Go GC's
  9. Scuba Steve
    ah, shut up....:p
    ;) just kidding. I love your car Brian
  10. Bielke55
    Okay mister is change my wings,trunks, and emblems like a woman changes shoes... Ha ha sorry off topic... i should update my pics i have had some changes since then.
  11. Scuba Steve
    whoa, i don't kno what kind of woman your dating by MY gurl changes her **** daily. I change my trunks only weekly;) :biggrin:
  12. Scuba Steve
    Congrats to TBone!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!:cool:
