avo turbo kit for sale
Discussion in 'For Sale : Car Parts' started by meejoluj, Jun 14, 2005.
  1. meejoluj
    meejoluj New Member
    need to get rid of this kit to make room in my garage. IT is the complete turbo kit if you need specs look on spomotorsports.com or rallitek.com, i'll also give you the full exhuast 2.5 into 3 in muffler, a hks super sequential blow off valve, autometer boost and a/f ratio in the pillar pod. If you want i'll give you a used ACT clutch witch still holds very well because i dont drag race.
    $2000 Meejoluj
    P.S. if you need pics, look at the other post about a crashed 00 rs turbo
  2. k_thaosta
    k_thaosta Well-Known Member
    willing to part out?
  3. TheWRX
    TheWRX Well-Known Member
    Off Topic: Hey meng do u still have the suspension from ur rs, the one I saw when I stopped by..
    Mohd
  4. dfish007
    Online
    dfish007 Guest
    uhhh. tempting, i have the cash, but i sold my gsx to buy somthing realiable...did you have any problems with the kit? was is basicaly bolt on and have fun or did you have to play with it alot. whats it use for fuel managment. i'll look up the specs in a minute.
  5. Dynapar
    sorry to but in but i thkn i can answer some questions. the kit was being run at 8 PSI for about 3 yrs? i dont think there were any plroblems with it. the computer is tuned for 8 psi.
    to instal the kit you need to drop you current exhuast and bolt in the new one. run the turbo lines and set up the intercooler and plug in the computer. i bet ya at 8 psi you could RIP although how much gas you would use would be interesting to see.
    good luck! AVO says the kit at 6 PSI wil make 200+wheel
  6. RallyNavvie
    RallyNavvie Well-Known Member
    My car gets ~26mpg highway. Different turbo kit but it's running rich so I bet it can be better than that when properly tuned. It's pretty interesting to see the fuel economy stay about the same on the RS with a turbo kit.
    As for those numbers they are probably a bit off. I can see 200 at the wheels running 8psi maybe. It's still going to be a fast GC Impreza, take it for that definitely.
  7. dfish007
    Online
    dfish007 Guest
    i'm gonna do a compression test serously think'n about it. It's only been 5 weeks without boost but i'm missing it so much!!:p
  8. meejoluj
    meejoluj New Member
    the suspension was sold, the turbo kit is a direct bolt on like dynapar said, the fuel and ignition is all controlled by the piggyback computer. It has been tuned for 7-8 psi and i never had problems with it. it runs a little rich to be on the safe side. it was made to run on a stock car so if you have other mode done to your car, you will get more power.
