bad gas mileage
Discussion in 'Modifications And Maintenance' started by scrltspedstr, Dec 19, 2011.
  1. scrltspedstr
    scrltspedstr Well-Known Member
    sooo i am getting about 17-20.
    i don't bass it all the time but I'm not saying i don't.
    could a new tune help?
    i fill up almost twice a week right now and am not happy about that.
    any suggestions as too why or things that may help?
  2. ofspunk7
    What gas do you buy? Example 93 from BP or 89 from holiday.
    Are you warming up your car?
    Mods and car?
    Take into consideration the winter gas mix?
    What were you getting before?
    Give us a better picture.
  3. Mr.Tran
    Mr.Tran Well-Known Member
    Sounds about normal due to winter conditions, IMO. My gas milage drops in the winter quite a bit.
    ofspunk7 likes this.
  4. john
    john Well-Known Member
    What year is the car, how many miles? Perhaps an O2 sensor is on the way out, or try a different fuel station.
    You don't "bass it"?
  5. Tash
    Tash Well-Known Member
    I bass it all the time. Many things in the winter can make millage go down.
  6. Scott
    Scott Well-Known Member
    That's all my 2002 wrx with 94000 all stock gets on average. And i bass mine anytime i can. I use mainly kwik trip or holiday. Usually i see about 255+- miles on a tank. Should i realy be disappointed? Looking at the car and driver reports that is where itis supposed to be?
  7. RexNEffect
    leemoreno likes this.
  8. john
    WTF does "bass it" mean? Are you fishing? Cranking up the stereo?
  9. idget
    oh, of course... bass it!
    1_sic_rex, leemoreno and Medic_538 like this.
  10. Medic_538
    Medic_538 Well-Known Member
    I get just shy of 300 to the tank. I don't run my defroster though. That runs the ac compressor and will drop mileage as well. I let my car warm up to operating temp every start and still get 22-25. Oh and I don't bass it. I am assuming he is refering to putting a drain on his car through some hotlanta music....lmao
  11. Bielke55
  12. jonny8852
    jonny8852 Well-Known Member
    In the summer I average bout 24mpg. So far this winter I am averaging about 19mpg
  13. idget
  14. scrltspedstr
    slapping he bass biiiiiiiiiiiig time.
    stupid lion spellheck
    i meant bass it
    its about 17-18 now and in the summer its was only 19-20
    seems kinda low imo.
    2004 wry 2.0 123000
    bp 93
    warm it up for a few minutes
    i get about 210 when the light hits
  15. Bielke55
    Sheen come get some Ham....
  16. AWDimprezaL
    No no no, not bass it, I meant bass it.
  17. idget
    This needs to be quoted.
    This is you, isn't it?
  18. Subie Lovers
    When was the last time you cleaned your MAFS... I was having issues with gas mileage and rough idle... cleaned mine and +3 to 4 MPG(thanks Eric). Most people on NASIOC clean theirs every oil change to once a month.
  19. Subie Lovers
    Or maybe he used this wire schematic to provide P-Bass to his car... [​IMG]
    Bass it up!!!!
  20. john
    I'm rolling here, broham!
  21. john
    What. The hell. Are you saying. Eh.
  22. ChubbyRacing
    ChubbyRacing Well-Known Member
    i get bad gas mileage too... like 16 mpg. w/semi built 4eat w/2500 stall converter. idk if that means anything.
  23. jas3087
    jas3087 Well-Known Member
    Did you mean MAFS? (as in mass air flow sensor) just so i understood clearly....
  24. Subie Lovers
    ^corrected, thanks
  25. MNSubie22
    MNSubie22 New Member
    I'm kinda drunk right now, and reading all of this is hilarious. Not making much sense OP, but in all seriousness I drive a Stage 2 STi and my gas mileage blows. Right around where you are saying and my MAFS is clean. That damn peddle on the right just gets pushed down too far and my gas gauge plummets.
  26. ofspunk7
    I check mine every oil change and I check my air filter. It takes a minute to clean. Then I really bass the hell out of my car.
  27. 02subbieRS
    02subbieRS Well-Known Member
    This thread contains much win :)
  28. john
    My '05 LGT is stage 3-ish, and with the 91 octane tune I can see 24 mpg if I keep my lead foot out of it.
  29. scrltspedstr
    DAMN LION SPELLCHECK!!!
    i meant gas it. i don't gas it to heavily too often.
    maybe i should proof read.
    though i do like the replies to my retardedness(i learned. spellcheck tried to "correct" this to retiredness, whatever that is)
    ill check my mafs.
  30. Tash
    So refreshing to read these fun threads
    02subbieRS likes this.
  31. idget
    Ohhhhhhh. Gotcha. It all makes sense now. Personally, I gas it heavily.
    tangledupinblu and scrltspedstr like this.
  32. ofspunk7
    The MAF cleaner is less than $10 a can and lasts a long time.
  33. Subie Lovers
    ^ what cleaner do you recommend
  34. retreif
    baby wipes.
  35. Mr.Tran
    I've got some you can use.
  36. Subie Lovers
    Yes... I been meaning to use that recently... Text me saturday or Sunday maybe we can meet up.
  37. Mr.Tran
    I have work Saturday morning, but I'll be free in the afternoon otherwise I'm off Sunday.
  38. Subie Lovers
    Thanks for bumping this... I still chuckle while reading this... I'm off at 3 Saturday and hope to get off early Sunday for the burger run... Text you Saturday
  39. leemoreno
    leemoreno New Member
    this is still FunnYYYYY Bassing stuff!!!!!!!!!!!!!!111
  40. LesMiner
    LesMiner Active Member
    This at the tail end here but I have noticed a more significant drop gas mileage this year over last. It was like a one tank difference! The oil companies change to a winter blend gasoline that probably increases the ethanol. Ethanol has a lower BTU content than gasoline. They hope to reduce gas line freezing. This winter no chance of that. Diesel fuel also has a winter blend but for different reasons.
  41. idget
    But how hard do you BASS IT?
  42. LesMiner
    This is a daily driver. 26 mile commute at freeway speeds. Typically cruise at 70 to 75 mph. So pretty sane driving. See my other post THE TRUTH ABOUT WINTER GAS. Does not matter if you BASS it or not winter gas means lower gas mileage.
  43. idget
    You're doing it wrong... the sense of humor part anyhow.
  44. Subie Lovers
    I would have asked the same question.
  45. AWDimprezaL
    Now that the temps are warmer, have you been hitting the bass hard, or no?
    Medic_538 likes this.
