bad pcv?
Discussion in 'Modifications And Maintenance' started by silverrs, Jan 22, 2008.
  1. silverrs
    silverrs Well-Known Member
    What exactly can a bad pcv valve cause your car to do? Run rich? Not start? Bad idle? anyways all help will be greatly appreciated...Thanks in advance...btw the car is a my00rs...
    edit: seems like an easy fix with the wallet also...ill get this fixed asap...now can somebody tell me what a cam 180* out is?
  2. shineynitelite
    oil pan gaskets, i suppose it could burn some oil, valve stem guide seals... i guess i didnt realize turbo cars had pcvs
  3. silverrs
    sorry the car is a my00rs...
  4. shineynitelite
    yeah i just realized that.
  5. AWDimprezaL
    bad gas mileage, seal issues, the part is like 10 bucks and it takes 3 minutes to install
  6. driftin240
    driftin240 Well-Known Member
    Not so much on the bad gas mileage, but you can build up excess crankcase pressure and possibly push oil past seals.
  7. driftin240
    Just pick up one, they are cheap, and easy to replace. Yours will be into the intake manifold in the middle area. Just to the left of your throttle body, if your looking under the hood. It should be grey, or rusty...
    19mm wrench or socket.
  8. silverrs
    thanks all....ill replace this asap...
  9. driftin240
    A what? Are you asking what a camshaft 180 degrees out?
  10. dman
    dman New Member
    Get an OEM pcv. They are better.
  11. AWDimprezaL
    PN# off the top of my head....11810AA000 i dont recall the price though, i'll look tomorrow
  12. driftin240
    Truth ^^^^^
  13. driftin240
    I have a few of them too, we won't sell out before you show up...
  14. shineynitelite
    i'm also confused
  15. driftin240
    Duh, that's cause your huffin NOS...
  16. shineynitelite
    it doesnt phase me.. :hsugh:
  17. silverrs
    i guess its kinda a stupid question but yea what is a camshaft 180 degree out?
  18. shineynitelite
    can you use this in context please, origin of the sentence, alternate pronunciations also
  19. silverrs
    nevermind i was wondering b/c i redid my timing belt and on my drivers side cam if i spun it to get it to TDC and it passed a certain point the whole cam would automatically spin...but on the passenger side cam i could turn it as much as i want and it wouldnt automatically spin ike the other one? just wondering if that was normal...
  20. driftin240
    Yes, that's totally normal.
  21. silverrs
    if my valves were bent or damaged in any way would the cams be able to spin like that? thanks for all the help...
  22. driftin240
    Umm, it could've happened if the belt broke while you were driving it, but just by you spinning the cams over by hand, I doubt that you would've bent the valves.
  23. driftin240
    The cams can still spin over just fine if the valves are bent, because the valves will be stuck partly open. Why do you ask?
  24. silverrs
    why do i ask? haha actually the story is i am in school in AR and my car died on me...just driving around and all of a sudden it lost power and died..it starts idles for 5 seconds then dies...this happened a week before school started so i had some time to check some things...things that i have check and replaced are spark plugs, wires, coil pack works, starter, checked my injectors b/c i am running so rich that my plugs are already fouled out...i replaced my fuel filter...so i am getting fuel and spark...then i cleaned my IACV valve...didnt do anything...so i got codes read and it was just my front o2...replaced that problem still persisted...so i redid my timing belt...nothing...i gave up and took it to the shop...after a week they returned it and said they didnt know what to do either...sooo i just got my car back yesturday and am ruling out maybe little things such as the pcv....and maybe valves being bent....but however once in a while the car will start and idle w/o dying but run pig rich and the engine sounds fine...no knock ping or pong....i am pretty confused b/c most of the time it does not start...
  25. driftin240
    I don't think the '00 has a MAF sensor, otherwise I would say check that. Is your CEL on right now?
  26. shineynitelite
    a shop didnt know what to do huh.. sounds pretty worthless
  27. AWDimprezaL
    5 bucks says its the MAF....(if equipped)
  28. driftin240
    That's what i'm leaning towards, I just don't remember if the '00MY had them.
  29. silverrs
    nope no MAF.....my00 comes with MAP...no CELs right now...only CELs were the front o2 sensor....replaced it already...BTW allsubaru.com only sells them for $63 and its the wideband one... ;)...the shop said it was a grounding issue but then they said they fixed that and the problem still persisted...so i dont know...i was contemplating a swap but then my pocket is kinda empty right now...
  30. AWDimprezaL
    fuel pump? can you hear it turn on? fuel pressure regulator?
  31. silverrs
    its definately not the fuel pump...i was thinking a FPR but i dont know what the symptons of a bad FPR is and how to check one without actually replacing one...anyone know how to actually check it? is a wrx fpr the same as mine? i see a lot for sale cheap...thanks for all the advice and quick respones....
  32. shineynitelite
    fuel in the vaccuuuum line means a ruptured diaphragm
    you would need a running car to test it, fuel pressure gauge + vacuum line on/off.. thats the only way i know of, you'd also need the specs for the fuel pressure at idle in/hg and 0 in/hg
  33. driftin240
    Shiney's right,
    If you pull of the vacuum line on the FPR, and it's damp inside, you have a ruptured diaphragm. They don't normally cause problems like yours, they normally just cause hard starts/long cranking times.
  34. driftin240
    You may want to get your car to a dealer if you can. They did have an update for the ECM on that car IIRC, and it had something to do with the front A/F sensor.
  35. shineynitelite
    i forgot to mention that, i think this is prolly a timing issue..
    you hear any popping out your intake?
  36. silverrs
    actually sometimes i do hear a loud pop...then sometimes after that the next crank my car will start...however my vacuum line that goes into my FPR does occassionally pop off and when my car died my the vaccuum hose to the FPR was off....anyways thanks for the help so far....
  37. AWDimprezaL
    it shouldnt die when the line comes off, it should idle way up
  38. silverrs
    anyone know if a wrx FPR will work for an RS?
  39. shineynitelite
    i think your timings advanced too faaaa
  40. silverrs
    how can i tell exactly? i just redid my timing and it shouldnt be...but then is the popping an indicator?
  41. shineynitelite
    yeah .
  42. silverrs
    pretty weird b/c i am 100% positive timing is correct but i may just do it again....thanks
  43. silverrs
    ok i redid the timing this morning....its not a timing issue? possibility of a bad ecu? is there a way to check the ecu?
  44. Yang
    Yang Well-Known Member
    maybe you should give everyone more info about your car,
    It has a custom td04 turbo kit with a greddy emanage ult right? I think you're problem is electrical and it may be your piggyback.
  45. silverrs
    no i already zeroed out everything and disconnected all the forced induction components and everything so i am just running regular vaccuum...just like it was when it was N/A off of the ecu...;) preparing to pull it out this weekend but just maybe checking little things out before i do...i checked to see if the high flow cat was plugged but it wasnt either...
