Ball joints going out? Vibrating steering wheel.
Discussion in 'General Subaru Discussion' started by Jake underwood, Nov 28, 2015.
  1. Jake underwood
    Jake underwood Member
    So lately I've been hearing clunking at low speeds in the front while going over any bumps, replaced my sway bar links not to long ago, and I have a pretty nasty vibration in the steering wheel 60mph+ so my money is on the ball joints. Any other suggestions on why my car would be vibrating above 60mph? 2002 wrx. Thanks for any advice.
  2. derp
    here and now
    Tie rod ends, ball joints, strut mounts, could be any/all. Hit any nasty potholes recently?
    Jake underwood and silver03 like this.
  3. Krazylegz1485
    Oak Grove
    When my tie rod end went out I could feel a definite "shift" in the front wheel when I went back and forth between accelerating and not. Like push the gas, let off, push, let off. Don't remember a steady shake in the wheel tho, but still maybe something to check I guess.
  4. Jake underwood
    No potholes, been doing it since I bought the car about a month ago, originally I thought it was flat spots in the tires for the vibration but it still hasn't gone away. Just ordered a new set of wheels and ball joints, after those I'll have it aligned and hopefully the vibration will go away. Also any easy way to tell if my tie rod ends are shot?
  5. Krazylegz1485
    Oak Grove
    If you have the capability, jack up the front of your car so the wheels are off the ground. If you can wiggle the wheel side to side excessively (hands at 9 and 3) it might be a good sign that they're bad. You can also have somebody wiggle them while you lay under and look at them. Mine was really obvious and on one side only.
    While you're there, wiggle them up and down (hands at 12 and 6). If they move that way at all it might be wheel bearings. Not saying it is but just a simple check while you're already right there.
    Nhibbs and Jake underwood like this.
  6. pillboy
    Saint Cloud
    Just stating the obvious...don't get under the car while it is on a jack alone. Use stands.
  7. Jake underwood
    Thanks guys, ill be looking at them this weekend!
  8. Jake underwood
    Update: I replaced both front lower ball joints, all new brake pads and rotors, and the vibration is gone. I think maybe the brake rotors were warped causing the steering wheel to shake at 65+
    babiker712 likes this.
