battery
Discussion in 'Modifications And Maintenance' started by Speedemon, Oct 20, 2005.
  1. Speedemon
    Speedemon Well-Known Member
    I need a new battery. I am just going to go to auto-zone but i dont want to buy some pos. So whats a good one to get.
  2. krees23
    krees23 Well-Known Member
    Optima Redtop is the best
  3. Deride
    optima... and if you want cheaper get a top of the line interstate.
  4. WRX1
    Stay away from the red tops unless you plan on driving all winter. I would just go to fleet farm and get the biggest batt you can get. Red tops (spiral core) batterys don't last through the winter if they jsut sit. I have seen 7-8 of them die (2 myself) when they are just shelved over winter.
  5. RallyNavvie
    RallyNavvie Well-Known Member
    I've always just used whatever the best NAPA one was that I could buy.
  6. Substeroo
    Substeroo Well-Known Member
    I have a plain Optima dry cell in two of my vehicles. One is huuuuge. They both work well. I will be storing one of them this winter and I hope it holds up!
  7. Battle Scar
    Battle Scar New Member
    lightweight battery!!!! then put it in the trunk, i got a dynabatt, only like 15lbs
  8. tbone
    tbone Well-Known Member
    OEM Genuine Subaru biatches
  9. Chin
    Chin Well-Known Member
    My vote would be on just about any battery, other than the OEM. They are somewhere in the 375CCA range IIRC! Interstate, Die Hard, Batteries Plus....all going to be about the same, after all, they use the same technology. What you should look for is the CCAs >500 (I think most are) unless you are running a big stereo system, in which case a higher CCA or Red Top-type battery is a good idea. All of this is assuming that you are not looking for a weight decrease... If you are, I have an Oddessy battery in my trunk of the RS and it works like a charm!
  10. Zola
    Zola Well-Known Member
    Not only that, but I'm pretty sure there are really only 3 or 4 manufacturers of automotive batteries in the first place. There are just lots of different rebrandings.
  11. DISCOPOPE
    DISCOPOPE Well-Known Member
  12. Speedemon
    thanks for your help guys
