Best boost gauge splice location?
Discussion in 'Modifications And Maintenance' started by istoptofly, May 22, 2007.
  1. istoptofly
    istoptofly Well-Known Member
    finally got my boost gauge in, got the multi color one from glow shift gauges....so where is the best place to splice? or is there another method I should know about? Thanks!
  2. idget
    Clock or lighter is easy. Clock on 06 wrx has a dimmer line too if you need it. Just don't half ass it and tap into the fuse box.
  3. istoptofly
    ahh, you have pointed out my lack of specifics, lol, I should have said what I wanted to splice into, which is the pressure line for the gauge, but good info none the less!
  4. idget
    Oh. The tech manual says to cut the line coming off the bpv. Facing the intercooler, its the small line coming off the bpv to the right. Cut it 2 to 3 inches from the valve where the line bends and t it off.
