Blew my motor
Discussion in 'General Subaru Discussion' started by Jackstand, Dec 12, 2010.
  1. Jackstand
    Jackstand Well-Known Member
    So last night on my way home from dropping a friend off from work my motor went.... I got knoc and then nothing. Reguardless i have a new motor to drop in it i will just need some misc parts and i need some help with what i will need.
    Right now this is what i have, all of which is brand new:
    EJ257 block halves
    Balanced sti crank
    Rods
    New pistons
    Andrew Tech 2.0 built heads
    262 cams
    This is all i have. But i do have a lot of parts i can reuse off of the old WRX motor but what should i not reuse? Any advice/help would be greatly appreciated
    Nick
  2. turbo_turtle
    Which motor did you have?
    ~Dan
  3. BugIedIzzy
    BugIedIzzy Well-Known Member
    well first off check on your turbo make sure that didnt pick up any metal from the motor!! easy fix if it did just saying you could budget one in. . . . .
  4. Jackstand
    well i will throw a small turbo like a 34/39 on until i have the money to do the rotated kit that i have
  5. Jackstand
    I had just the stock wrx 2.0 motor
  6. readymix
    Oil and Water pumps should be replaced. Any gasketry, I'd get a full engine gasket kit from MTKA. I forget the part number, but it has everything you need for a re-assembly.
  7. turbo_turtle
    I think you could salvage the oil and water pump, just make sure you rebuild the oil pump. +1 on the full gasket set. I would also get a new oil cooler.
    ~Dan
  8. JasonoJordan
    miles on the motor might help determine what could be reused. if the water pump has over 80k on it id say get a new one cheap insurance that that one dose not go out
  9. AWDimprezaL
    I would advise against using your old oil pan, oil cooler, things that oil has touched.
  10. turbo_turtle
    It is interesting that you think the oil pan should not be resused. Being that the OP will have to take off the pan anyway, don't you think it could be cleaned in solvent? Or too much hassle because of the nooks/crannies?
    ~Dan
  11. AWDimprezaL
    I'm sure it can be done, its going to be very hard to get it completely clean though, for the price of a good pan for me its worth the peace of mind, you spent how many thousands of dollars on a build and its F'd because of some metal you missed inside the pan.
  12. turbo_turtle
    ^ Good point. Might as well go with the 2.5L pan to clear larger headers and why not throw in a beefed up pickup tube.
    ~Dan
  13. JasonoJordan
    +1 on the 2.5 pan. then u can run twinscrollz yo
  14. piddster
    Ten minutes in any hot-tank will clean an oil pan. I would be more worried about the baffling that is in the pan than the style. It is pointless to use a STi pan if you will never need it.
    I do not see a reason to replace the oil pump. It can be cleaned out with little trouble. If you like to cut corners however, maybe you should get a new pump.
    The oil to water heat exchanger is the major thing that needs to be replaced. You will never get all the particles out of it, unless you find a way to hook up a cleaning machine used for transmission coolers.
  15. Jackstand
    Thanks for all the input guys. I got it all figured out. I got the car home tonight after waiting 12hrs for a tow truck. I will be pulling the motor tomorrow and hopefully bring the motor up on Wednesday
  16. chewy911
    chewy911 New Member
    Definatley get a new oil cooler. Also new t belt, water pump, oil pump, belt pullies.
