Blinking cruise control light??
Discussion in 'Modifications And Maintenance' started by wings_23, May 4, 2008.
  1. wings_23
    wings_23 New Member
    my check engine light just went on and the cruise control light is blinking. 05 sti no mods. I just changed the transmission fluid and the rear diff. Loss of mpg lately.what does this mean?
  2. fobiawrx
    fobiawrx Fabiola
    your cruise control blinks and is disabled when you have a check engine lite. get the cel cleared and it will go away
  3. Squiggly
    Squiggly Squiggly
    my car does that for a bad 02 sensor.. if thats your case it might explain the loss in mpgs as well
  4. bikerboy
    Just bad advise there Matt. We all have seen plenty of these threads. You should go to the local Checker and use there scanner and find out what the code is and report back here. We then can determine what things to look for.
  5. fobiawrx
    fobiawrx Fabiola
    well when you get it cleared you see what it is. my bad on the wording of my post. figured it was common sense on you see what it says and fix it...
  6. TSTRBOY2004
    :eek3::eek3::eek3::eek3: no way... ha haa
  7. AWDimprezaL
    loss of MPG and a CEL have a pretty good chance of being related.
  8. wings_23
    wings_23 New Member
    I had it checked at Autozone and it was misfire in cyinder 4. But after I shut it off and started it 2 minutes later the check engine light was off. I asked the guy if he erased it and he said no, I said are you sure you didnt do it accidently and he told me it takes more than pushing one or two buttons.
    What is a misfire in cylinder 4 mean, the car is running besides the poor mpg. And the light was on for only about 20 miles of driving and then shut off???
  9. BoBo82
    BoBo82 Member
    same exact thing happened to me, and I have an 05 STi as well.
    happened a few minutes after I left the car wash. I got some K&N sock thing that keeps water out of the SPT intake filter I have. probably the sensor like others have mentioned. my light hasn't come back on since that one time.
  10. AWDimprezaL
    crappy gas perhaps? i think you said you run holiday sometimes, i consider it to be terrible gas
  11. BoBo82
    BoBo82 Member
    all I use is holiday 93 pretty much
  12. AWDimprezaL
    I dont wanna turn this into a gas thread, but holiday is the worst of the worst, just because its 93 octane doesnt mean its good, man i would love to see what your exhaust valves look like.
  13. BoBo82
    BoBo82 Member
    I was always told holiday was good stuff. most of their stations only carry 92, but I found a spot with 93. what do you suggest? BP or what? I want to continue with 93, not many places seem to have it.
  14. AWDimprezaL
    do a search, there are a few gas threads floating around :)
  15. wings_23
    wings_23 New Member
    A misfire in a cylinder is as simple as just bad gas? The guy at auto zone says something about blowing up an engine. Is it weird that it shut it self off.
  16. AWDimprezaL
    it could be alot of different things, dont listen to the auto zone clowns
  17. Bullwinkle
    Your ECU will turn off the CEL after a number of restarts (can't remember how many), if the original problem that caused the CEL doesn't occur again.
  18. Chin
    Chin Well-Known Member
    Could be plugs or wires...or a whole lotta other stuff.
  19. AWDimprezaL
    sti's dont have wires ^^^
  20. bikerboy
    I would start with new plugs and reset the ecu and report back if the CEL reappears. If you want some piece of mind you could do a compression test as the same time the plugs are changed that will save some labor.
  21. subynate
    subynate Well-Known Member
    i have the same issue with my 07 wrx. but when i look for the cel on my ap it says no error codes found ???? im thinking its my rear 02 sensor since a bolt rattled out and i had a sweet exhaust leak and i was basically running a straight dump off the turbo...anybody know?
