blinking cruise light??
Discussion in 'Modifications And Maintenance' started by 763WRX, Jun 30, 2007.
  1. 763WRX
    763WRX Well-Known Member
    Ok me and some of the guys in stalled in a DP for my STI. Drive it no C.E.L yet until today. ( DP installed thursday) and when the CEL finally came on the cruise light starts blinking with it too! Is this suppose to happened? cuz on my wrx only CEL came on. Can anyone tell me what is wrong? DP is a Invidia Divorce wastegate type. Any help would be appreciated thanks!
  2. LegacyPGT
    LegacyPGT Well-Known Member
    the beauty of any suby with the drive by wire, once the cel comes on it also kills the cruise and throws on the cruise light. just get a resistor for the 2nd o2 or get a cobb AP which you should already have if your installing a dp on a STi
  3. Bullwinkle
    Get some EM.
  4. ShortytheFirefighter
    IIRC the electric CEL fix doesn't work on the 04+ models. The mechanical fix works just fine, do a search for mechanical CEL fix to get the right part number for the spark plug antifoulers, it works great.
  5. DISCOPOPE
    DISCOPOPE Well-Known Member
    EM wont do **** for the cat cel.
    it will however allow some sort of boost control which is what bullwinkle is hinting at....
    stack 2 antifoulers like brian suggested.
    it works wonders.
  6. Bullwinkle
    ??? :crazy:
    You can disable every CEL in the book with Enginuity...
  7. DISCOPOPE
    disabling the code will just stop the lite from blinking.
    your still ****ing up your ltft's.
  8. Nuke
    rear o2 doesn't do much if you're catless
  9. DISCOPOPE
    the ecu reads information that is used to calculate long term fuel trims from the rear o2. in essence modifying your fuel maps.
    many have therefore believed that a mechanical fix that retains stock like voltage, is the preferred solution.
  10. DISCOPOPE
    you can actually see the effect if you run a log.
    iirc in delta dash it's fuel correction #3..
  11. kvang
    kvang Well-Known Member
    I bet it is a p0244.
  12. Shibbs
    Tune.
    /thread.
