Blown tranny????
Discussion in 'Modifications And Maintenance' started by Ej22TIM, Nov 21, 2007.
  1. Ej22TIM
    Ej22TIM Well-Known Member
    So, you all know that the roads are sh1t right now, anyways i came up to a red light a little too fast so i had to lock up my brakes (no abs) and immediately after that my trans is, sloppy? you have to push the shifter all the way as far as you can forward for it to go into 1st and in all gears, you cant feel it even go in.
    It feels like my shifter linkage isnt even hooked up to my trans (impossible because it still goes into gear but you get the point)
    so..... has this happened to anyone before?
    i havent had a chance to crawl under it because of the snow.
  2. Dynapar
    perhaps in the emergency stop something slid loose. you might check the bolts/springs to make sure they are all tight and there.
  3. Ej22TIM
    I will look at it tomorrow, after a turkey nap lol
  4. FuJi K
    what tranny??? bent clutch fork??
  5. Deride
    If it is something with the linkage I am pulling mine out of my tleg very soon, and would give you the shifter linkage for free.
