Selling all my Subaru parts (since I now drive a completely soulless car). Everything is OBO. Send me a DM to schedule a time to take a look; I'll be checking my messages daily. $800 - STI 04-07 Brembo Calipers Sandblasted and ready for powder coat. Perfect to add a custom finish to your Subie. Comes will all hardware pictured including, but not limited to, all the pistons, assortment of seals and dust boots, pad retainer hardware, Titanium (ooohhh, ahhhh) bleeders. Not pictured - OEM Brembo O-rings to mate the case halves. Basically, everything you need to build and install these calipers. $300 - STI 04-07 Brembo Calipers I rebuilt these some time ago and had them powder coated blue. However, I stripped a bleeder on one of the rears and pulled all four calipers off. Aesthetically, they are in poor-to-OK shape. Functionally, they work fine as long as you can fix the bleeder opening.... Worst case, you need to scrounge a new rear caliper for the set. $100 - KNS Caliper Bracket V2.0 - Brembo Kit I ran these on my 2010 Legacy GT so as to be able to mount the 04-07 rear Brembo calipers. They worked great. I yanked them when I yanked the Brembo calipers (see above). I had them sandblasted as well - ready for powder coating. Also, comes with brand new high quality mounting bolts. $50 - 2 front/2 rear KNS 4K Rotors for Brembo Calipers on Legacy GT I ran these on my 2010 Legacy GT and yanked them when I yanked the Brembo calipers (see above). I don't know what other models they mount to. The rear rotors fit the drum parking brakes that some Subies run. They look pretty rough but have lots of life left in them. If you wire brushed them and spray painting the non-braking surfaces with high temp paint, they'd look good as new. $125 - Used STI Cams Bought these off NASIOC some time ago and left them in box. They appear to have some surface rust but I suspect nothing serious. Comes with springs, valves, and exhaust AVCS gears. $350 - 4 x Deatschwerks EV14 1000cc Brand new, never used. $10 - Infamous Performance Turbo Filter Anybody remember when the banjo bolt filter on 05-10 Legacy GT was (perhaps unfairly) determined to be the culprit to grenading VF40s (due to oil starvation)? If so, you get two stars. Do you remember the shop Infamous Performance out of Cali that seemed to dominate the Legacy GT space for some reason? Then, you get another star. OK, do you remember the turbo supply oil filter system that Infamous Performance cooked up if you were to remove your banjo bolt filter but still want some filtering pre-turbo? If so, that's another star for a total of 4 freaking stars. Anyway, if you want a piece of history, here's your chance. $5 - Lisle Spill Free Funnel <not pictured, in near perfect shape> $10 - Boost Leak Tester
Oops, these aren't sold $800 - STI 04-07 Brembo Calipers. Make me an offer, anybody! These sold - $300 - STI 04-07 Brembo Calipers.
