Bugeye wagon rear seat delete
Discussion in 'Modifications And Maintenance' started by Zer0, Jul 3, 2011.
  1. Zer0
    Zer0 Active Member
    So im currently working on a rear seat delete for my bugeye wagon and am looking for some carpet to finish off the delete. Does anyone know where i can buy some carpeting or where an apolstery shop is at?
  2. svxninja
    svxninja Well-Known Member
    what kind of carpet are you looking for because you can buy some at like menards or home depot
  3. Zer0
    Zer0 Active Member
    i would like to find something that matches the original carpet in color and as far as material goes, im not too picky as long is its a good quality material
  4. Threshld1
    Threshld1 Well-Known Member
    Might I inquire as to what you are doing with the rear seats?
  5. Zer0
    Zer0 Active Member
    right now the rear are just sitting in the garage but i need to use the rear seat bottom as a guide to make the front part of the delete after that mostly likely will try and sell them
  6. Zer0
    Zer0 Active Member
    or did you mean what i am doing to amke the seat delete?
  7. nimblevictoria
    nimblevictoria Well-Known Member
    what are you going to do with no seats? just gut it for the extra space?
  8. Zer0
    Zer0 Active Member
    First i dont like having to haul people all over and i mostly got the wagon for the ability to haul stuff the problem was once the seats are down they sit up at an angle and it cuts down on the amount of stuff i can haul and also when they are up at an angle they dont look good like that. Also in the spare tire area its all divided up into multiple pieces. My goal is to make it all into one piece and and eliminate the angled area, so the rear seat area and the spare tire area all one height. For now im jsut going to make it flush with were the rear seat originaly sat. I thought about some how including a sub box into the build but money told me otherwise. I had some stuff done recently and cant work on the car now but once im over this i plan on doing a DIY with some pictures that should be up starting later next week
  9. dmoo
    dmoo Well-Known Member
    1. sell wagon
    2. buy baja
    3. ...???
    4. Profit because of less work involved?
  10. TrisNiN
    TrisNiN Well-Known Member
    But then he would not have all the internal space, which is what he likely going for. I think it is a cool idea for those that have no need for the rear seats.
  11. Black_peter
    Black_peter New Member
    I'm all for that! I loved having a two seater, my last hot hatch I pulled the seat backs out after that I had an MR2. You don't get guilted into taking people all over...
    I would check out custom stereo installers. When I installed my amps in the front boot of the MR2, I made a "cover" for that opening. I got the low pile that matched the trunk
    from one of the suppliers we used.
  12. AWDimprezaL
    Do you mean brat? Bajas are 4 seaters too.
  13. Zer0
    Zer0 Active Member
    i can see where some people would see it as being pointless but for me its more about not always being the driver everywhere and leaving the are for later on doing a custom sub setup
  14. Zer0
    Zer0 Active Member
    finished the my rear seat delete in my wagon here are some shots of the whole process just wanted to get everyones opinon
    P7120151.JPG gutted the rear half of the car
    put down knock off dynamat
    cut out and fit the false floor bottom
    laying out the carpet
    Final product
    just another angle of the finshed product
  15. AWDimprezaL
    It looks like its very well done.
  16. Black_peter
    I agree, looks stock..
    What did you do around the front? Or do you just not use the rear doors. lol
  17. Zer0
    Zer0 Active Member
    i picked up some dense foam and shaved it down and so it didnt stick out past the new floor wrapped that in carpet leaving the bottom of the carpet longer than the foam. With the carpet longer i used that to tuck under the rear seat base (rear seat bottom was used as a filler) giving it a finished look but still is 100% removable if i wanted to return to stock
  18. Zer0
    Zer0 Active Member
    heres a shot of the side and it wraps all the way around to the other side
  19. Vector
    Vector Rally Organizer
    That's a nice, clean job, looks great.
    But why go to all that trouble to get a continuous space and then toss that strut tower bar in and break it all up?
  20. Zer0
    Zer0 Active Member
    thanks for the positive feedback guys, but the strut tower brace has i guess what you could call quick disconnect style hardware on it so when i would need to put something in the back all i have to do is remove the hardware between the strut mount bracket and the bar itself. To do that only takes about 30 seconds for both sides so its not too bad
  21. idget
    Looks good. Nice work.
    I'd suggest some sort of mounting hardware if there isn't any already... unless they're solidly mounted to the floor, those 2 pieces look like heavy projectiles to me.
  22. Black_peter
    Nicely done sir!
  23. Zer0
    Zer0 Active Member
    I had some concerns that they would be 2 giant projectiles like idget said but after getting the carpet wrapped the rear half is locked in there good and tight so that wouldnt be a concern but for the front half that would be a problem. So i went to home depot and fount some decent looking window latches that would pull the two pieces together. Ended up with two of them on the outer egde between the two halves. The picture above that shows the whole thing is from before i installed the latches. Heres a shot of one of the latches
