Everything here is used and is at your own risk; priced accordingly– no returns. Items are cross listed. All items can be picked up at JM Automotive Monday through Friday 7:30 AM to 5:00 PM and Saturday from 10 am to 2 PM. Please ask for Jesse, Devin, or Paul to help you – they are kind enough to help me sort out my collection. Call or text me with any questions: 612-275-7398. Not all pictures uploaded due to size - I will see if I can add them later. EJ257 Gates Timing Kit – 2500 miles - $20 SOLD Mishimoto Forester XT 04-08 Radiator – Repaired - $175 APS Coolant Overflow Container – Can’t get these anymore - $75 Crawford AOS – needs good cleaning but came out of running car - $125 Hallman Manual Boost Controller - $50 TD04-13t (02-05 WRX) turbo – works fine, missing coolant and oil lines - $150 2005 STI Gauge Cluster – can’t recall exact miles, but around 84k - $250 2004 Forester XT Manual cluster – 124K - $100 STI Stock cluster surround - $20 Forester XT cluster surround - $20 SRS Cat Back Exhaust – low miles, but is missing a hanger - $300 2004 Forester XT steering wheel with clock spring and airbag - $150 Metal coolant upper reservoir - $10 2004 STI Stock BCS - $5 2004 STI front rear bumper foam - $10 Stock STI sifter (I have 2) - $10 each Random Samco Coolant Hoses - $10 Aeromotive Stealth 325 LPH fuel pump – has been sitting in gas for a couple of years - $50 Aeromotive Fuel pressure guage – unknown condition - $5 Sparco 6 Spd shift knob – I can’t get it apart - $10 Deatschwerks 320 LPH fuel pump – low miles, excellent condition - $100 APS front mount blow off valve – again, can’t get these in US anymore - $200 Innovative LC1 wideband 52 mm gauge, controller, and sensor - $125 SOLD T1 Racing development side feed TGV to Top feed fuel injector rails with hardware – $150 GD Impreza map light - $5 2004 STI clutch master and slave set - $30 2.5 RS EJ25D intake manifold with EGR block off – professionally powder coated - $150 Various Steel braided oil lines or fittings - $10 ea GD WRX or STI accessory belt cover 2005 STI brake booster and master cylinder - $75 SMY GD Impreza gauge cluster gauge pod – has been trimmed to fit in a forester - $25 SOLD GD Impreza 3-guage A Pillar gauge pod GD impresa center clock plastic – no clock - $5 Prosport and sport comp gauge assortment – all working, but may need sensors - $150 for all Boost, EGT, oil pressure, fuel pressure, oil temp, trans temp – includes some various new sensors and wires Random Intercooler piping and silicone pieces – if we can make a kit for you…. $100
Correct - these are for side feed to top feed conversion. T1 specifically sells these with ID injectors, so there might be a special o-ring needed. I never installed as I went for ported top feed TGV's instead.
yep, I'll take $5 for the cover. I'm 180 mile away, so the JM guys,will help you out when you get there. I don't recall what the knob is from for sure, but I think it was a 6 speed.
