building motor
Discussion in 'Modifications And Maintenance' started by asiandude, Oct 12, 2005.
  1. asiandude
    asiandude Well-Known Member
    check out this set up...what do you guys think...any good
    price at 4g with core i believe so
    COBB's Short Blocks consist of a carefully chosen set of components
    engineered to be used together. Our 2.0L EJ20 Short Block features:
    EJ20 WRX High-Pressure Die Cast Short Block (2.0L Displacement)
    Cast-Iron Cylinder Liners
    Strong Billet 4340 Steel Connecting Rods
    Custom 92.5mm Turbo Forged Aluminum Pistons (8.0:1 CR)
    Heavy-Duty Chromoly Piston Pins
    Anti-Friction Piston Skirt Coating
    Ceramic Piston Crown Coating
    Turbo Specific Piston Rings
    Prepared Forged Chromoly Crankshaft (75mm Stroke)
    Wire-Ringed Cylinder Deck
    Computerized Balance of rotating assembly
    8000 RPM Recommended Rev Limit
    All Short Blocks are sold with a $1000 Refundable core charge. You have 30 days from the date of purchase to return your original short block to there factory. All short blocks must be in rebuildable condition to receive full refund of core charge.
    The term Short Block refers to the cylinder block itself, without cylinder heads, water or oil pumps, or any accessories located outside of the cylinder block
  2. Zola
    Zola Well-Known Member
    Hm, it's Cobb, so I would anticipate delivery of such a shortblock approximately the week we land a man on Mars for the first time.
  3. bikerboy
    roflmao
    Or just have someone build a block. I am doing several over the winter, :shock:
  4. Speedemon
    Speedemon Well-Known Member
    axis stg 2
  5. readymix
    You can get an Axis Stg2 for 2099 right now. 2.5 STi block with forged pistons and rods.
