Built 04' sti (Blown head gasket) - $12,000
Discussion in 'FS: Cars, Motorcycles, Boats' started by 2barsti, Sep 7, 2012.
  1. 2barsti
    2barsti Well-Known Member
    I'm looking to sell my 04' sti. Vehicle has around 7xxxx miles on the chassis and 13xxx miles on the motor. Vehicle made 483whp at 21psi on e85 on MAP's dynojet with my old bosch 1000cc injectors. Should easily see over 500whp with the current injectors on e85. Vehicle is tuned on Speed density.
    The only down fall to this vehicle is that is has a blown head gasket. Will need new head gaskets + getting the heads and block resurfaced, maybe ditch the MAP studs for ARP's too. I'm looking to sell the vehicle for $12,500. Alot of $ has been invested into this vehicle.
    Wiseco Pistons, Stock Bore 8:9:1 compression (Refreshed piston rings)
    Eagle Rods W/ ARP Rod Bolts
    MAP H11 Heavy Duty Head Studs
    Cosworth Bearings
    Polished &Balanced Crankshaft
    08 Sti 11mm Oil Pump
    Gates Timing belt
    Cusco Engine Mounts
    Exedy Twin Disc Clutch w/ AMS Clutch SS Line
    TiC Shifter Bushings
    TiC Clunk Killer Differential Race Bushings
    Agency Power Pitch Stop
    Agency Power Short Shifter
    M2 Peformance 3" Exhaust (Vband)
    Agency Power Equal Length Header
    Grimmspeed TGV Deletes
    Grimmspeed Phenolic 8mm Spacers
    FIC 1680cc High Impedance Injectors
    DW300 Fuel Pump with STM rewire kit
    FIC Topfeed Conversion Fuel Rails
    Fullblown High Flow Fuel Pressure Regulator
    Fullblown Oil Catch Can
    Fullblown Custom Stock Location PTE6262 Turbo Kit (Vband Downpipe & Uppipe)
    Fullblown Custom Aluminum Turbo Inlet
    Perrin Air Filter
    Tial 38mm Wastegate
    Tial 50mm Q BOV
    Mishimoto Radiator
    Fullblown Rebuilt 6speed Tranny, New OEM 3rd, 4th, 5th Gears
    Fullblown Manual Boost Controller
    AEM Tru Boost Gauge
    AEM Wideband Gauge
    Turbo XS FMIC
    Driveshaft Shop 600hp Rear Axles
    Agency Power Shift Knob
    Ksport Coilovers (Rear driver side is starting to clunk)
    Ultra Racing Strut Tower Bar
    Omni 4 bar Map Sensor
    17x8.5 Volk Racing CE28N's
    255/40/17 Kumho Ecsta XS & 245/40/17 Dunlop Direzza Star Specs
    Muteki Open Ended Lug Nuts
    There might be more stuff that I"m forgetting.
    Will get updated pictures when I get home.
  2. 2barsti
  3. AspitFire
    who put the motor together?
  4. Ronnie@RSmotors
    I believe it was built by fullblown. It has since been opened up at least once to replace the gasket and/or head studs. I'm assuming since it was last sold when it was pushing coolant out the radiator cap under high boost.
  5. KA-T_240
    KA-T_240 Well-Known Member
    You got any better pictures?
  6. 2barsti
    I will get some tomorrow after work.
  7. 2barsti
    $12,000.00
  8. 2barsti
    Have some updated pictures of the car. Left the key and camera at work, so I wasn't able to push the car out of the garage to take some pictures, hopefully I'll have some updated ones by this weekend.
  9. 2barsti
    $12K with everything or $11K and you bring your own wheels.
  10. white bugeye rex
    white bugeye rex Active Member
    car still available?
  11. 2barsti
    Yes, car is still available.
  12. white bugeye rex
    firm on 12k?
  13. 2barsti
    $11.5K is the lowest I'll go.
  14. 2barsti
    Bump...
  15. KA-T_240
    Bump! Someone buy this today with no wheels so i can buy the wheels from it while I'm down for the dyno day tomorrow :)
    Id love the wheels lol!
  16. 2barsti
    Bump, $11.5K.
  17. 2barsti
    *PENDING SALE*
    Ctracey218 likes this.
  18. 2barsti
  19. BroCo
    BroCo Moderator Staff Member
    Congrats on the sale! Shut down time!
