can anyone tell me how the engine knock sounds like?
Discussion in 'Modifications And Maintenance' started by chokin, Feb 22, 2007.
  1. chokin
    chokin Well-Known Member
    Plymouth Now
    well ...my engine sounds a little different to me ....im worry about engine knock, but i dont think so ...anyways ....if u guys can tell me , or there is some sound clips or video clips ...
    thanks!!
  2. bikerboy
    on the water looking for the sandbox
    Knock as in rod or as in detination?
  3. chokin
    Plymouth Now
    ^ when i brought my car in, was my car knocking at all ??
  4. AWDimprezaL
    Monticello.
    so your car has always been making this sound? check your oil, if it was bad you would know there was somthing wrong
  5. chokin
    Plymouth Now
    ^ im not really sure, but it sounds normal to me...hahha i couldnt tell tho ...but its time to change the oil ....do u think u can listen to it later when i stop by??
  6. AWDimprezaL
    Monticello.
    yup i'll listen to it, subaru motors all (accept for 6 cyls) seem to make at least a little bit of noise
  7. chokin
    Plymouth Now
    ^ that might be the little bit of noise ur talking about ...anyways just in case...
  8. tangledupinblu
    Online
    MNBugeyeMafia#001
    knock....knock....knock....knock....knock.....new accessport map making ya noisy maybe!? I know its not from the headlights!!:laugh:
  9. Sogonerg
    Sogonerg Anteater
    Earth
    Whose there!?! Ping! Ping who? The Pinging noise under your hood...
    I bet you pop the hood and a bunch of immigrates come out...that is what's causing the noise...
    What I mean is...find a good mechanic *hint* Bikerboy or LegacyPGT and have them do all your work to get the car back to tip top shape...Too many chefs in a kitchen is not a good thang...whether it is maintenance issue or repair...Find one u trust...
  10. tangledupinblu
    Online
    MNBugeyeMafia#001
    *....ROFL....*.....damn cobb accessports:eek4:hahaha
  11. WRX1
    Over there
    When is this noise happening?? If it is under wot, then it could be det, if it is happening at idle, it is something else. Knocking under wot will sound like bb's in a can, but if you can hear it you have some MAJOR MAJOR knock issues. If you are running a ap with a ots map, i doubt that it is knocking enough to hear.
  12. chokin
    Plymouth Now
    ^ thx guys , i stopped by Minnetonka subaru and had eric listen to it, he said my car sounds normal ..
