Car Chirping Problems!!!
Discussion in 'Modifications And Maintenance' started by JeWrX, Jan 21, 2007.
  1. JeWrX
    JeWrX Well-Known Member
    Woodbury
    I have an 02 wrx, and you know if all the doors are not closed and you hit the lock button on the remote the car chrips three times? well, i had the door opened and the car made the noise, so i closed all the doors then hit the lock button again, and it still makes that noise. It has been two days and i have tried turning on and off the chirp but no matter what, doors open or closed the car chirps three times when i hit the lock button (and by chirp i mean the damn horn honks) Also, now the alarm is going off randomly (well only twice but still) Anyone know what happened? its like something got switched and cant switch back....please help, this is a hitch in my sale!!!!!!!!!!
  2. chokin
    chokin Well-Known Member
    Plymouth Now
    is ur trunk open too ....??
  3. JeWrX
    Woodbury
    well its not open,and i dont think that matters?
  4. bikerboy
    on the water looking for the sandbox
    Might want to go to each door and open it. There are buttoms with rubber boots over them. Pull the boot off part way to expose the black post for the switch. Spray come carb cleaner in gap around the black post, just a quick shot. Then push rapidly a dozen times. Then give them a couple of twists. If you have a compressor blow them out a little if not no biggie. Once you have done all four then disconect the Negitive terminal for a few minutes.
    That should eliminate the switches being bad.
  5. JeWrX
    Woodbury
    yeah my trunk got iced over and didnt seal properly, the funny thing is, now the alarm works, before when i hit the lock or unlock it did just that, now the lights flash when i lock or unlcok and when i unlock the dome light goes on, sweet!
  6. shineynitelite
    st. paul
    if you need a new box and remote i have one.
