Car doesnt want to start when warm
Discussion in 'Modifications And Maintenance' started by RichWRX, Jul 9, 2006.
  1. RichWRX
    RichWRX Well-Known Member
    Orr,Mn
    Well I finally got my car done after 2 turbo kits and 2 new turbos, the car starts fine when cold but doesnt want to idle, im guessing its just a software problem. Im going to get a new map monday. But after you drive the car for a while and shut it off it doesnt want to start again, if you wait 20 minuites it starts up with no problems, could this be software related?? or is there something else that could be wrong?
    Rich
  2. TSTRBOY2004
    vapor lock in fuel supply??? dont know sorry....
  3. RichWRX
    Orr,Mn
    Ive been searching the net all day and came up with a few things hopefully its one of them
  4. bikerboy
    on the water looking for the sandbox
    Is this the hydra? If so I would say you are looking at an issue with the warm start map.
  5. RichWRX
    Orr,Mn
    yes it is the hydra. im going to call phil tomorrow and hopefully he can send me a new map for me to load, I have the exact setup he is running in his car
  6. snbrd4evr
    snbrd4evr Well-Known Member
    Eagan, MN
    I can probably help you with it. Startup sucks... big time. If you need any fine tuning, give me a call and I can try to help. Shoot, send me the map right now and I'll play around with it :)
    And Data-log it... on the highest resolution (16hz or something like that).
  7. RichWRX
    Orr,Mn
    talked to Phil and this is what he said to do
    "Typically that is a sign of the car being too lean for the setup. I
    typically see this on cars with ported heads or cams. You will need to
    increase fuel at idle and you will need to increase the "cranking
    enrichment" at the higher coolant temps."
    so im hopeing that will help
  8. snbrd4evr
    Eagan, MN
    That's what I was going to do to it :)
  9. tbone
    tbone Well-Known Member
    MN
    Holly shizzle 2 turbo kits!!!
  10. RichWRX
    Orr,Mn
    the third finally fit
  11. tbone
    MN
    wait it minute, there're triblings? Meine Guete!!!!!!
  12. RichWRX
    Orr,Mn
    on the 1st turbo kit the uppipe and downpipe werent even close to fitting, on the 2nd it was even worse. and finally when I contested the charges they sent me one that worked, but the turbo had a blown seal so it leaked oil, so they sent me a new turbo last week and all is good.car runs but just needs some fine tuneing so it will idle better. im comeing down sunday to bring it home
