Car not starting (no sound when turning the key)
Discussion in 'Modifications And Maintenance' started by Panko, Jan 19, 2009.
  1. Panko
    Panko Member
    So I drove back from Iowa yesterday, parked my car for 45 minutes, went to start it up and nothing happens.
    Battery seems to be working as interior lights/radio works, but when I turn the key to start nothing happens, no noises at all. Same as if the clutch wasn't pressed in and you try and start it.
    Any ideas what I should be checking/ looking at?
    It's a 2007 Subaru WRX
  2. Ronnie@RSmotors
    make sure the battery has enough power to start the car. if its an auto make sure its in park. check starter wire.
  3. wrxsti_02
    wrxsti_02 Well-Known Member
    I had the same problem with my 02 wrx. Jump started the car and it fire right up. Test my battery at work and found out it was bad so I replace it.
  4. silver03
    cables on tight?
  5. putz
    putz Well-Known Member
    poles clean on the battery?
  6. TheHoboMan
    Try giving the car a jump before you do anything else.
  7. carl
    do you have a multimeter or a way of checking the battery's voltage?
  8. Panko
    Panko Member
    Thanks for the replies guys,
    so this morning when I went to try and start it again I noticed that I had the lights on parking setting. When I switched them to off I tried starting it and it started up. I drove it around for 15 minutes or so, and figure that would be enough to charge the battery, but when I shut it off it wouldn't start again.
    Do I have a dead battery?
  9. ShortytheFirefighter
    Your lights should go off automatically when the car goes off. Do you mean the switch on top of the steering column for the parking lights?
  10. legendx
    legendx Well-Known Member
    check the battery bud. its more than likely the issue based on the info you have provided.
  11. Panko
    Panko Member
    If I stomp on the clutch pedal really hard, I can get the car to start. Any idea what that means?
  12. ShortytheFirefighter
    Sounds like a clutch switch to me rather than a battery.
  13. Bullwinkle
    Also, 15 min of stop and go traffic driving is not enough to charge a dead battery. Personally, I'd recommend you charge the battery with a trickle charger or go for a long highway drive to charge the bat. From what you posted, it just sounds like you left the parking lights on.
  14. Shibbs
    At LEAST take the battery out of the car and let it warm up. THEN put the trickle charger on it.
  15. greg donovan
    probably a combination of a bad clutch switch, a drained battery and cold weather.
  16. Panko
    Panko Member
