Car probs...**Need help** 2000 2.5 rs
Discussion in 'Modifications And Maintenance' started by CrazyVaj, Jan 4, 2008.
  1. CrazyVaj
    CrazyVaj New Member
    Coon Rapids
    I Have a 2000 2.5 rs... Engine check is on and my engine is choking ..... Seems like not enough fuel or something... RPM idols from 1000 to 1300... when you step on gas the engine chokes and often dies, but if given no gas it idols ... Ill try anything.....
    Thanks much ...Steve
  2. Se7enrex
    Se7enrex Well-Known Member
    All over Slingin' Parts for the Hungry
    nice name va-j-j
  3. T-REX5000
    T-REX5000 Well-Known Member
    St Louis Park, MN...uptown really
    have you read the code to see what it is?
  4. CrazyVaj
    CrazyVaj New Member
    Coon Rapids
    error is what I got last time I tried that.... It's ether I did it wrong or the cars really a mess... I'm thinking that it could be my fuel pump but not sure... it seems when stepping on gas it chokes not getting enough gas...
  5. EggRoll
    EggRoll Well-Known Member
    STP
    That happened in my wrx, I got error when I tried to run the code, but after screwing around for three days I found out the sensor wasn't on right.
  6. stoooo
    stoooo Well-Known Member
    North Yorkshire, UK
    Changed the fuel filter lately ?
  7. CrazyVaj
    CrazyVaj New Member
    Coon Rapids
    yes, first thing I did three week ago???
  8. tbone
    tbone Well-Known Member
    MN
    maybe pcv is going bad....just pull the code it helps a lot where to start with
  9. CrazyVaj
    CrazyVaj New Member
    Coon Rapids
    Ill try again later to see what comes up...
  10. speedyham
    speedyham Well-Known Member
    Hastings, MN
    drive to autozone, get them to read the code, report back to us.
  11. Se7enrex
    always a pump.....
  12. driftin240
    driftin240 Well-Known Member
    Out West
    There are more than a few things that could cause that. Sounds like you need some help.
  13. CrazyVaj
    CrazyVaj New Member
    Coon Rapids
    Found the Prob... thanks
    The problem was tha 02 senser...thanks for all the help....
  14. EggRoll
    STP
    glad you fixed it!
