Cellphone mount location
Discussion in 'General Subaru Discussion' started by boone1186, Nov 20, 2012.
  1. boone1186
    boone1186 Active Member
    Here is my deal. I want the mount my phone in an accessible yet non annoying spot on my dash. As I've discovered there are a million phone mounts/holders in many variations. I'm just curious how you guys have mounted your phones and what hardware you purchased to do so. Pics would be cool I really want to make sure I buy the right product the first time as I hate fussing with returning shat.. Thanks
  2. SKullman
    SKullman Well-Known Member
  3. john
    john Well-Known Member
    I've never come across a phone mount which was pleasing to me, so I end up using the cup holder.
    WillC likes this.
  4. Woot
    Woot Well-Known Member
    boone1186 likes this.
  5. SurlyOldManMN
    Not a bad idea. Particularly given how many cars come with multi-disc units now days.
    I've been happy with my $30 generic mount from Target. They only have one. It's flexible enough to work with my phone or Accessport. I like that disc thing though. I might do that in addition so I can have the phone and AP mounted at the same time without looking like I have scaffolding under my windshield.
  6. Shane86
    Shane86 Well-Known Member
    I put a panavice mount in my Legacy for my XM Receiver, which is planned to be temporary.
    Once i pony up and do the whole double din conversion, and integrate the XM, the panavice will be repurposed for my cell phone.
    it is a perfect distance from my finger, if i'm resting my hand on the gear shifter.
  7. WRXCarl
    WRXCarl Well-Known Member
  8. Mr.Tran
    Mr.Tran Well-Known Member
    I'm also looking to pick one of these up. Not crazy about the Mountek CD changer/optional bottom thing. I really like the look of that proclip.
  9. Neltech
    Neltech Member
  10. xluben
    I have to OEM Motorola dock stuck to the lower left of my windshield. It is a suction cup just like a GPS mount. I run the wire under my gauge cluster and get power from the lighter adapter. You can't even see the wires and it just plugs in and automatically charges when I dock it. It also recognizes the connection and pulls up the "mobile mode" on my phone. Easy access to GPS, etc. I really like it.
  11. boone1186
    The combined weight of the phone/mount don't turn the horizontal vent blades you attach it to downward?
  12. atacamaR
    atacamaR Well-Known Member
  13. Mr.Tran
  14. Woot
    not at all, if you look at the picture in the link,the top part clips onto your vent and the bottom part of the clip is actually a little foot that that holds the whole thing level so your vents stay straight, the whole thing is very steady never had an issue even bouncing down dirt roads, i actually hide my little febreeze air freshener vent clip kinda behind it too on the same vent. I will try to take a picture of it in my car at lunch today for you.
  15. atacamaR
    I see you point but I'm sure it's shielded enough where the magnetic field doesn't damage anything. it's not like ipads, hard drives, etc are magnet free. unless i'm reading it wrong i think only the hinge uses magnets. I'm not concerned as i don't expect my phone to get wiped out. who pays 500 for a smartphone anyway. :D
  16. xluben
    People that want to keep unlimited data on Verizon pay $600-700 :banghead:
  17. thakrazymule
    thakrazymule Active Member
    So I'm not the only one who does that? Haha
    This thing actually works quite well, except sometimes the jaws that ratchet tight to hold the phone slip and it loosens a little, but I got it used, so that could be why.
  18. Mr.Tran
    I didn't pay that much for my phone (I still have unlimited LTE Ben =P) I just meant the value. Regardless I'd need to see some research. How can it be strong enough to hold a phone but not strong enough to effect the internals of the phone? Is it possible? Sure but like I said I need research first. Not to mention I'm not a fan of it sitting with no sort of enclosure.
  19. JuStaWRX
    I have a pad mount that came with my Garmin that i stuck on to the dash right in front of the radio (04 WRX). It works nice, because I can use my suction cup phone holder, or the Garmin suction holder off of that. I prefer it over the window, because often times in extreme temp changes, I loose the suction, and then it drops while I'm driving. It also is at a nice height for me to glance quick, and stays out of the way for the radio controls, and also has straight access to the cigarette outlet power. If I were to do it again though,(if I read correctly) I would mount it on the side where Xluben was saying; bottom left of the windsheild.
  20. Chin
    Chin Well-Known Member
    Same setup for me... Motorola is good about supporting their devices with hardware. To bad I will never be buying one again after their latest issues (the Atrix 4G not getting ICS was the final straw).
  21. boone1186
    I bought this exact one from Amazon and it works like a dream for $21. Holds the phone well, installs in less then A minute. Only downside is limited placement as it does need to mount in a vent. Overall I'm satisfied for the effort/money I've invested.
    Woot likes this.
  22. JuStaWRX
    I too ordered one from amazon, and have really enjoyed it! Makes me nervous to tighten or loosen on the really cold days, but so far has been great.
  23. AWDimprezaL
    Exactly, they all look terrible, and your eyes are drawn to them.
