I plan on changing brake pads (stocks) to hawk hps should i swap the rear with the front, or is it ok to swap the front, then rear later?
the fronts would be your primary ones. the rear brakes hardly take up any braking force so they wear alot slower than the fronts. If anything, change the fronts first.
Do them both at the same time so you can bed them all in at once. (Assuming you're going to do the rears any time soon, but rears last a lot longer than fronts so you may not want/need to). http://www.zeckhausen.com/bedding_in_brakes.htm I'm still on my stock rears at 48k, but probably getting close to the end of my second set on the fronts.
