Check Engine Light and Cruise Light Flashing
Discussion in 'Modifications And Maintenance' started by KSAL, Sep 22, 2006.
  1. KSAL
    KSAL Well-Known Member
    Just as the title says. my Check engine light has come on and the cruise light is flashing. I run a Cobb catless Dp and a cobb catback exhaust. I was reading a little on IWSTI and i read a little about an 02 sensor?? Sound right? It just started happeneing tonight! When got home i took it out real quick to show my roommate and it seemed like it was hessitating when i was driving. Very noticable! It was jolting really bad! If you have any advice it would be greatly appreciated!! Thank you!!
  2. AWDimprezaL
    def figure out what code is throwing
  3. Dream
    overboost
  4. 6MTizzle
    6MTizzle 2SLO
    if you had it to the floor at the time i would bet overboost...check the code and post it up.
  5. Steve-o
    It's not the O2 sensor, those CEL codes are disabled by the accessport. Or you don't have an accessport....?
    ibmisfire1-4
  6. Scuba Steve
    Yes, he has the AP, so something is amiss.
    KSAL- plug that AP into your car, I beleive you can read the codes.
  7. KSAL
    OK! I can do that
  8. KSAL
    Ok I got code 0302 which is cilinder 2 misfire!
    i got 2 sets if ???????
    and i got code 1574 but i couldn't find it in the booklet so it looks like a trip to the dealership for me!
  9. Scuba Steve
    I believe the 1574 code is....O2 Sensor Circuit Low Voltage (Bank 2 Sensor 2)
  10. KSAL
    So a dealership trip is deffinatly in line??
  11. Scuba Steve
    I would probably check your plugs first before taking it to the dealer. how many miles on the plugs?
    another question...do you have a lightened flywheel or aftermarket pulleys? It's an outside chance, but I've heard they will sometimes throw a misfire code.
  12. KSAL
    Scuba Steve you are a smrt guy!! It was one of the plugs! A wire came out of the plug so they put it back in. It was under warranty so it was free. No biggy. Thanks for the help though!
  13. Scuba Steve
    thanks...glad it worked out:)
