Cleaning IC
Discussion in 'General Subaru Discussion' started by jonny8852, Apr 21, 2007.
  1. jonny8852
    jonny8852 Well-Known Member
    is there a good way to clean a Intercooler when it get dirty and everything?
  2. TSTRBOY2004
    air hose...
  3. beanflickr
    beanflickr New Member
    I use orange cleaner to clean the entire engine. Spray liberally on a warm (not hot) engine, let soak for 5 min, spray off with hose (preferably power washer, but a nozzle works too).
    Just don't forget to cover up your alternator and battery terminals with some glad wrap first.
  4. Justin
    Justin Well-Known Member
    i thought i heard somewhere that gas works great for that...not sure though
  5. sapalas
    sapalas Well-Known Member
    Are you talking about the inside? If so i would use a little bit of gas give her some shakes and let it drain out then be sure to run some water through it to flush the rest of the gas out.
