I'll plan on being at Firestone again this Friday (6-12). Prices are for cash. - 1999 Impreza rear drum brake shoes. Approx 60k miles. Good cond. $5 - 2000 OBS ebrake cables for drum brakes. $10 - Outback Sport rear knuckle with drum brake mounting plate. Broken abs tone ring and two missing studs. Knuckle and hub appear good and are interchangeable with disc brakes if you change the backing plate. $10
- 1999 Impreza L struts. 130k miles on stock springs. From my wife's car, no racing or anything. They're soft, but not blown. $20 - 1999 Impreza L front top mounts. 130k miles. Rusty, but they weren't clunking. Always run on stock struts and springs and no hard driving. $20
- ugly ganzflow intake for MAP based NA subarus. Wrapped and painted with hi-temp paint to keep the heat down a bit and make it a bit quieter (less tinny) sounding. $10 or trade for your stock fender plug. - Sirius receiver. I got this from sleeperwagon. Some buttons were not working, I re-soldered a connection to fix and it's all working great now, it may break again. Everything else you see is from a newer sirius kit, brand new wires and mounting stuff. It's in working condition now. NO SUBSCRIPTION. It may work for a while but you WILL have to subscribe. Great if you want to use a receiver you have in another car. $35 - Stock Impreza OBS shifter Shifter with two bushings only, no knob. For those that like a nice, long throw. $5
I bought the springs used from Yia (yang is his username). I ran them for about 40k miles on my car with AGX struts.
I want the fogs...... and the shock proof.... and the e-brake cables (if they are for a disc brake equipt car)....
Ok. Yeah, I can do that. Sounds good on the fogs and the shock proof, the ebrake cables are for drum brakes though.
ill buy that strut bar from you if it fits my 99 L wag which i believe it should..you said youll be at Firestone this fri? also could you bring that intake down to firestone as well? i also maybe interested in that
Yeah, the strut bar should fit. I had it in my 00 wagon. The intake is for MAP based NA imprezas though, I believe your 99 has a MAF. But I'll bring it with and we can double-check. Yeah, I'll plan to be down at FS again friday around 8:00.
