clutch help
Discussion in 'Modifications And Maintenance' started by shorty5198, Sep 18, 2007.
  1. shorty5198
    shorty5198 New Member
    well my clutch is slippin pretty bad on my 04 sti and i'm trying to find a good replacement. I'm going to be putting a 20g on the car so i want it to have a little more hold than the stocker. also, i'm trying to find one with a lighter flywheel but i might just have the stock one resurfaced. what would you guys do? tryin to keep the budget relatively low on this one but any suggestions would help. thanks alot
  2. Jackstand
    Jackstand Well-Known Member
    St Louis Park
    Well idk what your budget is but i got a stage 2 zoom for 500 and i like it a lot granted i just put it on but i noticed a big difference.
  3. Iroc-Z
    Iroc-Z Well-Known Member
    New Germany, MN
    If I was rocking an sti I would do the spec stage 3 clutch.
  4. Iroc-Z
    New Germany, MN
    Be careful with getting a clutch that is to strong. Cause if you clutch wont give that means the 5 speed transmission will give and thats not good.
  5. shorty5198
    ya i was thinkin a stage 3 clutch but i am just wonderin about the flywheel element, should i just have it resurfaced or is it worth it investing in a new lighter one since i'm going to be down there anyways
  6. Iroc-Z
    New Germany, MN
    Its 100 percent up to you. You will loose some rotational weight with an after market flywheel. But is it worth the cost? I don't personally think so. I was in the same shoes you were six months ago. I just resurfaced the stock one and reinstalled it. For the 300+ dollars for an after market one I could put that money to better use.
  7. Nuke
    Saint Paul
    +1 for resurfacing the stock flywheel
  8. Justin
    Justin Well-Known Member
    St. Paul, MN
    we can resurface the stocker for you if you need.
    Justin
  9. shorty5198
    hmm decisions decisions
  10. piddster
    Boostonia
    Ask p3tis about the Spec stage 3+. He likes it but says its a bear in traffic.
    I'm in the market for a 6mt clutch as well. I'd like something streetable, but will hold what my turbo will put down. The ACT SB4-HDSS sounds nice to me, and it supposedly will hold 475 lb-ft, which is about what my turbo will support, with different heads of course.
    Spec stuff looks nice, and a kevlar disk may be nice, but the stuff is spendy.
    What I really want is the Exedy Hyper single carbon, but I cannot justify $1900 for a clutch and flywheel.
  11. PRA4SNO
    PRA4SNO Well-Known Member
    nunyah
    Talk to Fuji K!!!!!
  12. shorty5198
    already did, hes going to be doing the install. i think i'm going to go with clutchmasters stage 3+their aluminum flywheel. seems like a decent price
  13. NMDAYTIME
    NMDAYTIME Well-Known Member
    i'm in the same boat i have a 04 sti and i'm doing the clutch myself. i'm going to see if the boss will let me do it in the shop or i'll just do it in the garage of my home but i went with a stock flywheel and a stage one clutchmasters. but i'm wondering when you open the hex plup to pull the pin to pull the fork what bolt do you need to pull the pin? also when should i drain the fluid? and i really dont want to pull the axels is there another way besides that and pulling the motor? all depending anyone want to help? :)
  14. subytek
    subytek Well-Known Member
    Further west than Ted.
    The big pin in the tranny has a threaded hole in it, just screw a bolt in it and pull it out. Also you do not have to drain the tranny fluid to do a clutch.
  15. piddster
    Boostonia
    Just make sure you put some rags or something in the holes for the axels and the driveshaft. I learned the hard way with about 2 quarts of gear oil spilled under the car that I had to smell for two months. :roll:
  16. FuJi K
    St. Paul, MN
    The stocker is pretty light for an STi flywheel. Probably weighs 13-18lbs
  17. tux121
    tux121 Well-Known Member
    Champlin
    can the 6spd tranny take a stage 3 clutch?
  18. 6MTizzle
    6MTizzle 2SLO
    South Side
    I love my spec stage 3+. It holds the 20g powa and was pretty reasonable. I did not purchase a flywheel with it, I just had the stocker resurfaced. As Piddster mentioned it can be punishing in traffic. A little bit here and there is ok but heavy stop and go traffic will give you the left leg workout.
  19. NMDAYTIME
    i know the pin has threads in it but do you know the thread pitch of the hole
  20. subytek
    No, but I'll try to get you a answer by tomorrow night.
