OK Guys...Give it to me...I don't know nothing..So explain to me a bit about clutchs...Also if u know of a good website to buy a good priced clutch kit let me know...And if someone can explain what woud be better having the stock flywheel resurfeced or should I just buy a new one, what's the difference and advantages....Thanks alot... Mohd
This is a link someone else posted in another thread that was on here not too long ago, definately worth taking the time to read, it explains a lot about the types of clutches out there. http://forums.nasioc.com/forums/showthread.php?t=775679 I think getting the flywheel resurfaced is ok, as long as you don't have damage to it that makes the flywheel unfit to be used (cracked, warped, worn beyond specs...). A good resurfaced flywheel and a new replacement (stock) flywheel should perform exactly the same. Lightweight flywheels are another story, but other people know way more about that than me. Joel
