Yes, I just need to load the map and flash my ECU, I currently have OpenECU on as well, just tinkering around, but I dont have a map for 20g on OpenECU. I think its my VF39 that is causing all the smok'n. I hope the 20g will resolve this problem, I have all the supporting mod's except for a map. Thanks in advance.
Ok, the street tuner is the tuning software for a accessport. With that software you can tune your own car. Open ecu is basically the same thing without the access port. So what are you trying to do?? Russ
Ok, then do you have a ap?? If you have a ap it is just a matter of loading a map onto it and flashing it. No real need for the street tuner unless you want to custom tune it. Same thing applies for the open ecu, just flash a map to the ecu. Russ
Sounds simple, I done have a custom map, I found a StreetTUNER map for 20gDB beta, the AP mgr cannot see the map. OpenECU-I dont know anyone that has a map. -Cheech
Here is the link, recap, I dont have StreetTuner software, my AP ver1 can only read .ptb files. If you can help sent it to my email address which I'll pm you. Thnx -Cheech http://www.cobbforums.com/forums/showthread.php?t=31225 2004-2006 STi DB20GvBeta.zip http://www.cobbforums.com/forums/attachment.php?attachmentid=574&d=1176877061
