code help!
Discussion in 'General Subaru Discussion' started by RichWRX, Jul 15, 2005.
  1. RichWRX
    RichWRX Well-Known Member
    I just ran the code and got a Dtc p2092 Qcv solenoid valve signal a circuit open (bank 2)
    Detect open or short circuit of oil flow control valve solonoid.
    Anyone know what that is,or where I should look.
    Thanks
    Rich
  2. RichWRX
    I unhooked the utec and cleared the cel, started it back up and as soon as I pressed the gas the light came back on, any thoughts
  3. prezawagon
    prezawagon Well-Known Member
    The only thing I can find about the OCV (oil control valve) is in this article.
    http://autoweb.drive.com.au/cms/A_102200/newsarticle.html
    So it sounds like it has something to do with variable valve lift. Does the STI have that?
    Anyway, it says there is a valve at each intake camshaft sproket, doesn't sound like anything easily accessible. Maybe there are some wires visible that you can check the connections on.
    Joel
  4. RichWRX
    Thanks,
    I actually found the same article, I might be sending my Utec back to turbo xs to see if there is anything wrong with it.
    Rich
