Cold Air Intake
Discussion in 'Modifications And Maintenance' started by ej20, Feb 12, 2008.
  1. ej20
    ej20 Well-Known Member
    Just wondering for those of you with Cold Air intake, do you guys have any problem in hard rainy days. Especially on highways. Is a water by-pass-valve recommanded? Any NOT recommanded driving weather?
  2. Shibbs
    NO BYPASS. Turbos will suck those right open, unless they are designed for a turbo car. Even so, put a filter around it.
    If you still have all your splash shields you should be fine driving in heavy rain, just don't go crashing thru puddles.
  3. Nuke
    you're going to blow your engine up
  4. Shibbs
    :roll:
    Exaggeration MUCH?!
    It is however recommended to get a tune immediately.
  5. ej20
    besides tune
  6. Bullwinkle
    A tune will net you gains, but is not necessarily required for CIA's that're the same as the stock MAF.
  7. Shibbs
    True, but our 06+s compensate for the lack of turbulence much better than the 16-bit ECUs.
    ..Or so I've heard. Who knows for sure. Anyway.
  8. Nuke
    I'm giving him crap, ok? :laugh:
    Kong will always get picked on by me, just because...
    my K&N cai doesn't go all the way down to where it would suck up water.
    went through rainy days, no problem
  9. ej20
    just b/c I bought your K&N....
  10. wall of tvs
    No they don't.
  11. driftin240
    driftin240 Well-Known Member
    I have a short ram, and was still having issues with water going through the filter and contacting the MAF sensor, throwing my AFR readings way off. Car would hesitate, misfire, and all that.
    Solution: Got a K&N Pre-Filter and cleaned/oiled the filter. No more issues.
  12. Rexwagon
    Rexwagon Well-Known Member
    Just make sure the filter is clean during the rainy season
  13. driftin240
    Even then, cotton filters can still allow some water vapor through, which CAN cause problems.
