Used flywheel. Resurfaced to comp spec's. $150 Competition Clutch Lightweight Flywheel for 04-15 Subaru WRX STI 2.5L Turbo EJ25 Competition Clutch Flywheel - Forged Lightweight Steel Flywheel: The Competition Clutch Forged Lightweight Steel Flywheel is recommended for naturally aspiriated and/or street driven applications. This flywheel will work with ALL performance and stock clutch assemblies. *Qualities of the CCI Lightweight Steel Flywheel* * Preserves low end torque and drive ability * One piece ring gear for high durability * Weight varies from 11 lbs. to 14 lbs. depending on application * Well suited for Stage 1 and Stage 2 clutch kit applications * Stamped with 4140 plate with 2000 ton pressure at 1260 degrees * CNC machined and balanced to O.E. specifications Reduced Mass = Increased Accleration Meets and exceeds SFI 1.5 The 2600 Series kit includes a performance pressure plate, a high torque sprung disc with segmented Ceramic facings, all applicable bearings, and the appropriate alignment tool.
