Compass/Homelink/Auto-dimming mirror
Discussion in 'General Subaru Discussion' started by Randy_Marsh, Nov 22, 2009.
  1. Randy_Marsh
    Randy_Marsh Member
    Does anyone know if all STis are wired for the Compass/Homelink/Auto-dimming mirror? Even if the car did not come with the mirror from the factory...?
  2. errorcode3
    errorcode3 Member
    i would guess no, since running wires for something that isn't there doesn't make sense.
    But then again i could be completely wrong, since i don't own one.
  3. Scoobyvroom
    Scoobyvroom Well-Known Member
    Remove the screws in the map lights in the headliner, look for a three pin connector in there I belive that is the power for the auto dimming mirror.
  4. STi Scott
    STi Scott Well-Known Member
    I think they all are actually. My '04 WRX came with just a normal mirror, and I put a Homelink mirror in that and it was pre-wired so I would assume that all of them are. I'm not 100% positive though.
  5. 02blubru
    its easier and cheaper to make one wiring harness for all impreza then to make several different ones. I am guessing the wires will be there.
  6. WRX1
    It is a port installed item, so it is some random monkey that plugs it in once the car gets off the boat. The wires will be there.
  7. webcrawlr
    webcrawlr Well-Known Member
    Pull the center map light down and look for the harness. From what I've heard they are all wired for the homelink/compass/auto dim. Being that the mirror is a dealer installed item it makes sense that they pulled everything just in case.
