Complete swap including tranny clutch master and slave linkage driveshaft clutch flywheel pressure plate tranny mounts and xmember rear diff (open 4.111) Wrx pedal assembly (aluminum pedals) shift knob bolts etc...... Diff has about 40k on it (needs new axle seals) everything else has 65k on it and is in complete working condition. Asking $700 firm. If you think that is high look it up on carpart for just the tranny with those miles .... All from a 2002 2.5 rs
are these the same gears that came in the wrx? im looking to upgrade my urbo and kno that i will need at the very least stronger gears, would these be a solution?
No, they are not the same gears as a wrx... different ratios. I'm guessing they are about the same strength as stock wrx ones.
