compression test
Discussion in 'Modifications And Maintenance' started by mnstilynwrx, Sep 11, 2006.
  1. mnstilynwrx
    mnstilynwrx Well-Known Member
    i was wondering how much something like this would cost? who can do it and what are some of the steps that take place. iam thinking since i still have a cel code for my car after i swiched the spark plugs and checked the coil packs that i would need to do this.
    thanks
  2. esperunit
    esperunit Well-Known Member
    well..
    If you just changed your plugs and you're geting a low compression absed CEL, I'd say you probably didn't put one of your plugs in tight enough.
  3. mnstilynwrx
    i dont think its that, any one else have advice? keep it comeing
    thanks
  4. AWDimprezaL
    Did you put in new plugs because you got the CEL? or after? like zach said, not tightening them enough would do that, they have a crush washer on them
  5. CBR04WRX
    CBR04WRX Well-Known Member
    What code is it throwing? What makes you think a compression check is needed? Got many miles? Overboosted & think you blew a ring land?
  6. mnstilynwrx
    it's throwing the cylinder 1 and 3 misfire. i had the spark plugs cahnged once, than later i changed them agin and also had the coil packs switched to see if it was one of those, and the code still came up after a while. i just figured that i maybe hade a low compression in one of the cylinders. it has 105,000 miles on it. and i dont think it's been over boosted.
  7. TSTRBOY2004
    injector clean maybe.. seems like you have addressed spark issue but not fuel maybe...?!?!?1 like an injector firing wrongly....???
  8. mnstilynwrx
    i have done some cleaning for them, seafom, and like octaine booster. but i guess nothing serious. is there something i could do for that? i know at your shop i got some kind of cleaning done, i dont know if it was just for the gunk in the engine or if it was for the fuel system.
  9. mnstilynwrx
    any more ideas keep them comeing.
  10. AWDimprezaL
    What year is your car? if its an 02 ide be concerned about burnt valves
  11. mnstilynwrx
    yeah its an 02 wrx. how much is that going to cost. if its that...
  12. Zombie
    Zombie Well-Known Member
    werd!
  13. mnstilynwrx
    is that what happened to yours zombie? you didnt get it fixed right. you just swapped to the 2.5.
  14. Zombie
    well, i'm 95% sure thats what happened based on the symptoms. but I never took the motor apart to find out for sure. The car was 100% stock and then low compression at 140k so I just did the swap.
    You burning any oil? Do a compression test too. I would do one sooner than later before you make a rebuild on your current motor more expensive.
    But hopefully its something trivial. good luck!
  15. mnstilynwrx
    no i have not been burning oil. and yeah i will do one soon. i hope its not to expensive or to big of a problem....
