COTM Contest: August 09'
Discussion in 'General Subaru Discussion' started by Bielke55, Jun 29, 2009.
  1. Bielke55
    Hopkins
    Not impressed:mad:... That was a weak showing.
    So I Guess i gotta up the ante huh?
    If we get more the 6 Entries for COTM for the Month of August. I will give the Winner a Prize.
    Heres the Winners Prize
    Now ONLY! If we get 6 or more entries will I give away this Prize...
    New Theme!
    Theme: Photos Must Be New! Or Freshly Taken!
    RULES COTM for August 09' :
    -Pictures must be current from 2009 only AND Be taken in the Month of June - July 09'
    -Pictures must be the your car
    -Pictures can be taking anywhere
    -Only THREE photos per entry
    -Photos can NOT be the same as Previous COTM entrys.
    -Lets try to keep it local (in MN), unless you moved, but still are active member.
    -Keep all the complaing out of this thread, Send me or the mods a PM or post in this thread if you have an issue http://mnsubaru.com/forums/showthrea...highlight=cotm
    -Me and the Mods make the final decisions
    -Voting starts on the 24th and ends the 31st
    -All Previous Winners are eligable!
    GL everyone
  2. AWDimprezaL
    Monticello.
    I'm gonna win two months in a row. Different vehicle this time however.
  3. fondune
    abou this. we'll see. no we won't.
  4. Shane86
    Shane86 Well-Known Member
    St Louis Park, MN
    Shane D.
    2004 Subaru Impreza WRX
    Java Black Pearl – STX Prep
    Vehicle Modifications:
    Suspension
    -JIC FLT-A2 Coilovers (Custom Valved)
    -Whiteline 27mm Front Sway Bar
    -Whiteline HD Front Endlinks
    -Hypercoil 575lb/in Front Springs
    -Whiteline Steering Rack Bushings
    -Whiteline 24mm Rear Sway Bar
    -Whiteline HD Rear Endlinks
    -Hypercoil 700lb/in Rear Springs
    -Whiteline Adjustable Rear Lateral Links
    -Custom Milled Front Camber Plates
    -Carbing Front Strut Tower Brace
    Wheel/Tire
    -17â€x8†Enkei RPF- 01 (Gold)
    -235/40-17 Dunlop Drizzera Z1 Star-Spec
    Engine
    -APS 65mm Cold Air Intake
    -Gutted Stock Up-Pipe
    -Bosal Divorced Wastegate Down-Pipe
    -Custom 3†High Flow Cat Mid-Pipe
    -Blitz Nur-Spec R Cat Back with Custom 3†Flange
    -Custom ECU Reflash
    -Lightweight Hawker Racing Battery
    Brakes
    -TheBrakeMan Stainless Steel Lines
    -Valvoline SynPower Brake Fluid
    -Hawk HP+ Brake Pads
    Drivetrain
    -STI Short Throw Shifter
    -Kartboy Shifter Bushings (Front & Rear)
    -Turn in Concepts Shift Linkage update
    -Turn in Concepts Shifter Bushings
    -STI Group N Transmission Mount
    -STI Group N Engine Mounts
    -Kartboy Transmission Brace Bushings
    -Turn In Contecpts Klunk Killer kit
    Interior
    -TurboXS KnockLite
    -Schroth Rallye-4 Harness
    -Alpine Head Unit
    -Infinity Perfect 6.5" Components (Front Doors)
    -Infinity kappa 5.25 Speakers (Rear Doors)
    2009 Season Upgrades
    (already purchased, pending downtime to install, or mounting hardware)
    -Innovative LC-1 Wideband O2
    -Innovative Thin Digital Gauge
    -Prosport Gauges (Oil Press, Oil Temp, Water Temp, EGT)
    -Corbeau FX1 Seat
    -ATI Center Gauge Pod
    All 3 Pictures taken 2 Weeks ago, at the June 20th Autocross at Miller Park, in Milwaukee, WI
  5. bobafett04wrx
    bobafett04wrx New Member
    Kittyland Love Center
    Heres my entries. They were taken last weekend near Aitkin. Added a few new ones with the new trunk.
    Mods:
    K&N panel filter
    Moto GP silencer delete
    STi TMIC
    STi hoodscoop and ducting
    Grimmspeed EBCS
    Optima Yellow top battery
    Grimmspeed up-pipe
    Invidia 3" Turbo back exhuast
    Invidia G200 cat back
    Bullwinkle stage 2 tune
    STi gauge cluster
    Auto Meter boost gauge
    STi shifter trim
    Sparco shift knob
    OZ Chronos 18" wheels
    Pirelli pzero neros 225/40/18r
    Rally Armor UR mudflaps
    H1 5000k pnp hids
  6. dhanso312
    dhanso312 Well-Known Member
    Minneapolis, MN
    My first entry
  7. retreif
    Somerset, WI
    Someone's getting a jacket. These are from this past Saturday and Sunday.
    Mods list:
    There are some.
  8. dhanso312
    Minneapolis, MN
    Come on everyone add your pics!!
  9. Bielke55
    Hopkins
    Only 4 Entries so far... The Months still young...
    I will be entring my own car in hopes to win myself a jacket!
    bUmP!
  10. h23
    h23 Member
    VF34 ball bearing turbo, ported/polished, ceramic coated
    MRT stainless steel turbo back exhaust
    MRT Top mount intercooler
    GPMoto equal length headers, coated, integrated uppipe
    STI pink injectors
    Walbro high flow fuel pump
    Perrin fuel rails
    APS TGV deletes
    TXS Hybrid bypass valve
    TXS intake with K&N filter
    Cobb tuning reflash
    Crucial Racing thermostat
    STI hardened engine mounts
    STI hardened suspension bushings
    STI hardened top hat strut mounts
    STI sway bars
    STI forged aluminum A-arms
    STI pitch stop mount
    STI pink lateral links & trailing arms with pillow ball bushings
    Zerosports V-Earthling grounding kit
    Whiteline anti-lift kit
    Whiteline G4 coilovers with adjustable height/damping
    Braided stainless steel brake lines
    Motul racing brake fluid
    Subaru 4 piston front brake kit
    DBA slotted rotors, cryotreated
    Carbotech pads
    VIS carbon fiber hood
    VIS carbon fiber trunk
    Hella Supertones
    Morette headlights
    SPT short shift kit
    Zensho 17" wheels Toyo m+s tires
    Scotty's cocktail transmission fluid
    Rally armor mudflaps
  11. Bielke55
    Hopkins
    Awesome H23... Can you show or date these photos?
  12. Shibbs
    The bottom two are 7/7/9 as per the EXIF. Taken with a Sony DSC-W150. :)
  13. h23
    h23 Member
    Correct, all were taken yesterday :)
  14. Ylime
    Female
    uptown
    mods:
    hella supertones
    bullwinkle tunz!
    rally armor mud flaps
    megan racing turbo back
    invidia up and down pipe
    turbo inlet
    spt intake
    spt heatshield
    mishimoto radiator
    aftermarket radiator hoses
    sti rear sway bar
    bermbo blanks and bendex ceramic pads
    vector custom skid plate
    prodrive anthracite p1 wheels with black lug nuts/ sumitomo hrtzIII tires
    stock wheels and ultra grip ice rated tires for rallyx and winter
    jdm rear mid wing
    full sti interior including door cards and front seats
    07 sti limited stereo
    30 tint all around
    kartboy exhaust hangers
    jdm sti hoodscoop and spiltters
    custom made ylime emblem
    drak grey painted headlights
    thats all I can think of for now...thanks.
  15. Aegis
    Female
    サイレントヒル
    Car looks good, Em! :biggthumpup:
  16. Ylime
    Female
    uptown
    thanks!!! props to russ for the awesome pics!!! :biggrin:
  17. Bielke55
    Hopkins
    Can't let you guys walk away with my jacket!
    2001 Impreza 2.5RSTI
    Info:
    Engine:
    EJ257 Block
    STI Crank And Rods
    Wiseco Pistons
    Bronze Valve Guides
    7-Angle Valve Job
    Port and Polished Heads
    Port and Polished Intake Manifold
    Legacy Turbo Exhaust Manifold
    T28 Turbo (Ebay Turbo Right Now)
    Custom 3" Turbo Back Exhaust
    SPT Air Filter
    Hydra EMS Tuned By Ronnies @ RS Motors
    ACT Stage2 Clutch
    Exterior:
    Hella HIDs and Supertone Horns
    STI Fog Covers
    STI 22BB Hood Vent
    MB Wheels Mesh X
    215/45R17 Falken RT-615
    Magnaflow Muffler
    Suspension:
    KYB Adjustables
    H&R Springs
    21mm WRX FSB
    20mm RS RSB
    Front Ebay Style Strut Tower Bar
    Interior:
    Prosport Green/White Gauges
    Carbon Hood and Holder
    PLX Wideband
    Leather RS Seats
    Ebay Style SS shifter
    STI Duracon Shift Knob
    All i can think of for now...
    HUGE THANKS TO Hotcarl!
  18. AWDimprezaL
    Monticello.
    Looks hot bilktits! Love you!
  19. fondune
    i just can't get enough.
  20. h23
    h23 Member
    F'n A Bielke, there goes my jacket
  21. Roon
    Roon Well-Known Member
    Isanti
    I might have to get the gold wheels of intercourse in on this. Stay tuned (Need pics :( )
  22. 03subyR
    03subyR Well-Known Member
    South suburbs, Boston
    Might as well post my car too. Pictures were taken today.
    Mod list for MY 08 WRX:
    Engine
    DB Td06-18G turbo
    Desthworks 650 injectors
    Invidia catted DP
    SPT cat back exhaust
    AEM cold air intake
    AVO TMIC
    Turbo XS BOV
    Stainless steel oil line kit
    GMBCS
    Suspension
    09 WRX front struts/08 STI springs
    08 STI rear shocks/STI pink springs
    rallytek fron and rear sway bars
    AVO front and rallytek rear endlinks
    Other stuff
    STI rear spoiler
    Harmonmotive rear lights overlays
    Rally armor mud flaps
    Prosport boost gauge
    HID 5000k headlights
    Drag 17x8 rims
    Continental extreme contact 225/45/17 tires (all-season)
  23. Roon
    Isanti
    My Entry,
    2007 Satin White Pearl WRX TR
    The List -
    70mm APS CAI
    Lowered on Cobb Springs
    Invidia Bellmouth DP
    Perrin single tip cat back
    Stage 2 tune done by Jordan @ MAP
    Tommy Kaira 18x8 Pro-R's in Gold
    Dunlop Direzza z1 Star Spec's
    The Pics -
  24. Scuba Steve
    In the Co-Driver Seat
    Pics taken at June Bug Rally-X, June 28th 2009
    Car: 2000 Impreza RS/L
    Mods:
    Suspension
    GR-2 struts
    Swift springs
    22mm 3-way adjustable rear sway bar
    Kartboy endlinks F&R
    Brakes
    Rear disc brake conversion
    Goodrich braided lines
    Engine/Transmission
    Short ram (hot air intake) ;)
    WRX Engine mounts (they were laying in the garage)
    WRX Transmission mount (Same...it was laying there)
    Energy suspension shifter bushings
    Other crap
    2.5 RS Front bumper & Fog lights
    2.5 RS Coupe trunk & spoiler
    WRX Wheels
    STI Muffler & custom mid-pipe
    Radiator Shroud
    3/8" skidplate
    Kartboy shift knob
    Best part of the car? 87 octane!!!
    Future mods
    More gas and maybe even an oil change
  25. tonyM
    craig kelly is my copilot
    ^^^ do we get to share the jacket as I am in 2 out of 3 of your pictures?
    :) ok I'll settle for background props. haha
  26. Bielke55
    Hopkins
    Thats not fair!
    You can't just take pictures of the sexy rims!!!!
    J/K :laugh:
  27. carl
    we gotta gooooo
    his rotors look rusty, i can't vote for rusty rotors
  28. Ylime
    Female
    uptown
    nah there just colored matched! :laugh:
  29. carl
    we gotta gooooo
    not really sure who to vote for this month... the codriver? or my awesome pics?
  30. bobafett04wrx
    That and his mnsubaru stickers are on backward.
  31. Bielke55
    Hopkins
    lol Its a private vote Carl! Dave will never know!
  32. Ylime
    Female
    uptown
    its a private vote carl..brian and dave will never know about it
  33. Roon
    Isanti
    :), might have been just a bad reflection! I dont know, I don't think my rotors are rusty, I use them quite often.
  34. Roon
    Isanti
    I keep hearing this, but now I am going to leave them that way and start a trend. The backwards MNSubaru sticker mafia, because well we have a mafia for everything else it seems.
  35. carl
    we gotta gooooo
    naw a lot of people have been doing the backwards sticker thing for years. that's how mine were
  36. Scuba Steve
    My vote would go to Brian..his car is sexy!:yumyum:
    On the other hand, if you show up at the rally with a cake I'll vote for you ;)
  37. Roon
    Isanti
    I know, thats why I thought I was putting them on the right way. Then I saw a few more of your posts and decided thats the last time I look at Carl's car and decide anything on it is "right".
  38. Roon
    Isanti
    What about me?
  39. carl
    we gotta gooooo
    those aussies make a hell of a car :laugh:
  40. bobafett04wrx
    Still looks wrong to me
  41. Roon
    Isanti
    diaf. :)
  42. Bielke55
    Hopkins
    Bump only 2 days left!
  43. sgrtits
    sgrtits Well-Known Member
    Female
    St Paul Park
    where did july go?
  44. Bielke55
    Hopkins
    Erik won with Court since no one did it.
  45. Bielke55
    Hopkins
