Craftsman C3 19.2-Volt Cordless 1/2'' Wrench Kit
Discussion in 'General Subaru Discussion' started by xluben, Oct 21, 2013.
  1. xluben
    If anyone is looking for a 1/2" drive electric impact wrench, this is about as cheap as you'll ever find one ($84.99).
    http://www.sears.com/shc/s/p_10153_12605_00931305000P
    The Craftsman driver's don't have quite as much power as some of the high end ones($300 to $500+), but 200 ft-lbs is enough for lug nuts and most other non-stubborn bolts. And for $85 it's quite a deal. A cheap Harbor Freight one is usually about $120.
    This kit is normally $140. With the 15% off deal right now I believe this should actually be $119. I'm not sure why it is listing as $85. Even on sale, $85 is actually the price of just the 1/2" driver (no battery or charger). So no matter how you look at it, this is a pretty nice deal.
  2. xluben
    OK, after I posted that I looked and it is actually that low of a price because it is on sale and there is an online discount right now.
    That particular item is on sale for $100 (normally $140), and the 15% off online deal is applied on top of that.
    Normally around the holidays these can go for as low as about $110, so this is still the best I've seen by far.
  3. GiMp
    GiMp Well-Known Member
    Fort Worth Texas
    I should order one.
  4. xluben
    You're always looking for the handouts.
  5. GiMp
    Fort Worth Texas
    Yeah but it never happens!
  6. xluben
    Stop asking. Just steal things.
  7. AspitFire
    MN
    nice! Thanks for posting. This is a great value for what you get.
  8. gc8
    gc8 Well-Known Member
    Champlin
    My buddy just picked up a Ryobi impact wrench for $99 (no battery or charger - tool only) and it's rated at about 200 ft-lbs as well. The Ryobi is an 18v...would this 19.2v have a little more oomph?
  9. GiMp
    Fort Worth Texas
    Sold
  10. Deride
    Awesome, this will go great with the rest of my 19.2v set!
  11. xluben
    I agree! Perfect for track days!
    It should be a little more power. And a way better deal. Battery and charger is probably $50 or more. I never had luck with Ryobi in the past. Not really a fan.
  12. JasonoJordan
    I like my lithium ion Makita
  13. xluben
    Yeah those are way better. And 3x-4x the price. Just depends what you need.
  14. JasonoJordan
    I got it and the drill with 2 batteries from home depot for $250
  15. Tim the Plumber
    Bloomington
    I have one of these and I love it. Its perfect for quick wheel changes. If you hit lugs right until the impact kicks in you won't over trq then a quarter turn with your trq wrench and your money.
    I have also pulled this bad boy out on some stubborn bolts that a friends lil home air tank couldn't get and it did the job.
    +1 for this.
  16. TMF
    Cool, thanks for posting.
    I have a John Deere 3/8" cordless impact that I've been using for years and it makes any job much easier and faster (especially for removing/reinstalling lug nuts on extended wheel studs!). The batteries are getting old, so I may pick one of these up.
    Does anyone know if the charger that comes with the impact can also charge the lithium-ion batteries? Or would I have to get a different charger to charge lithium-ion batteries? I was thinking about picking up an extra li-ion instead of ni-cad.
  17. Deride
    You need the lithium ion battery charger. The li-ion one will charge the ni-cad batteries though.
  18. TMF
    Good to know, thanks for the info.
  19. xluben
    Yep, you need the other charger. It is usually better to just buy something else that comes with a lithium battery and charger. It's basically the same price as just the battery and charger. So you can get a drill or something for free. That's what I did.
  20. pillboy
    Saint Cloud
    I will never buy another NiCad rechargable battery again after experiencing LiIon.
  21. xluben
    Expanding on this. This is the Lithium Ion battery/charger combo. Normally $80, on sale for $65.
    http://www.sears.com/craftsman-c3-19.2-volt-lithium-ion-battery/p-00935710000P
    A few months ago I bought this combo. It has the LiIon battery and charger, but it also has a drill and a 3/8" quick connect driver.
    http://www.sears.com/craftsman-c3-2-piece-lithium-ion-drill-and/p-00935701000P
    I'm not sure why it was so cheap, but I got it for $85. At the normal price of $140, then you are probably better off getting just the battery and charger, but if you see a good deal you can get some more tools for almost "free".
    Why do you say this? Is it performance over life? I do like my LiIon more, but mainly because it's lighter.
  22. xluben
    Surprisingly the 1/2" drive impact already showed up! Very fast shipping.
    I decided to take some photos to compare the 1/2" drive to the 3/8" drive and the NiCad battery to the LiIon battery.
    *Note: 3/8" drive is used and that is why there is discoloration on the grips.
    1/2" drive w/NiCad vs. 3/8" drive w/LiIon
    1/2" drive w/NiCad
    3/8" drive w/LiIon
    3/8" drive w/LiIon vs. 1/2" drive w/NiCad
    Batteries removed
    LiIon battery vs. NiCad battery
    1/2" drive w/NiCad vs. 3/8" drive w/LiIon (no batteries)
    Now, with the batteries swapped around. They are nearly the exact same height like this.
    1/2" drive w/LiIon vs. 3/8" drive w/NiCad
  23. AspitFire
    MN
    Got mine from the sears store the same day you posted it! Already putting it to use on my clutch job! Love it so far. You got a killer deal on that 3/8 + drill lith combo. ill have to keep my eyes out for that deal.
  24. xluben
  25. AspitFire
    MN
    Yea i bought it online, but clicked in store pick up, same price. Ill have to keep my eye out to see if that deal comes up for that set again, i wouldnt mind an extra drill and a 3/8 drive.
  26. Kurt Hollanitsch
    Kurt Hollanitsch Member
    North Branch, Mn
    Just picked one up. Should be great for the occasional use it'll get from me. Thanks for the heads up!!
  27. Stuart
    Stuart New Member
    kind of an old thread to bump but it looks like the deals are still on. Christmas tools are my favorite.
  28. xluben
    Looks like the 15% online deal is gone, but still good prices.
