hey all reading over what i need to do fir my oil leak fixage. i am checking out what i need to do to pull the crank pulley. do i need a chain wrench or anything to hold the pulley or should i just be able to put my ratchet on it and pop it off? same for putting it back on? do i need a wrench to hold the pulley whuile i tighten down the retaining bolt? also what are the torque specs on that bolt for a 2.2l my chilton has a typo and doesnt list it. thanks
The car should be in the highest gear possible on a manual (and probably on Park on an Automatic). That being said, have a second person step on the brakes while you untorque/torque the crank bolt. You gotta have a breaker bar, cheater bar, and an impact socket set. The EJ25 uses a 22mm socket. Did you need extra assistance with your crank pulley? If you're not too far away, I can stop and help.
my dad and i are going to do it tommorow, so i think we will be fine. its just he thinks we need a chain wrench to hold the pulley so it wont spin. (i dont want to put a chain wrench on my new UR pulley). hopefully i can have this all done and be at firestone tommorow.
I use the starter to pop loose the main crank pulley bolt Note which way the engine turns. Slip on the breaker bar with socket. Wedge it so it wont fly around and kill anyone. Unplug coil pack. Just barely hit the ignition switch and BAM its loose. Done it many times; use at your own risk :mrgreen: Yes, I am ghetto
Correct! As long as you're at or close to 100 ft/lbs, you're safe. Too much and the aluminum contact area of the pulley may deform.
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">Originally posted by morganm I use the starter to pop loose the main crank pulley bolt Note which way the engine turns. Slip on the breaker bar with socket. Wedge it so it wont fly around and kill anyone. Unplug coil pack. Just barely hit the ignition switch and BAM its loose. Done it many times; use at your own risk :mrgreen: Yes, I am ghetto <hr height="1" noshade id="quote"></blockquote id="quote"></font id="quote"> lol, my buddy tried that on a buick and it didnt work lol. it might be worth a try if i cant get it off w/ breaker bar. did you just prop it against the chassis (by fender)? double checking so no specail wrench to hold pulley needed for taking off or puttin on? and wat kinda coolant? green/orange?
Engine spins clockwise right? So prop it on the drivers side. I stick mine through the opening in my skid plate esentially keeping it from going either way too far Last resort, good idea. Should come off with liberal application of brute force and common sense Looks like you got a weekend of fun pland; good luck! :mrgreen:
i just found in m jy chilton book the torque specs. it says 76-93 ft/lbs. hope there isnt another typo!
